9.04 Creating Automated Coordynate Systems
Old   November 3, 2014, 03:36
Exclamation 9.04 Creating Automated Coordynate Systems
Christian
Chrismaster is on a distinguished road
Hello Everybody,
I got a problem.
I want to create automated coordynate systems on a cyrcled inlet / outlet Plane, with Z- Direction within the flow.
The Inlet/Outlet is, as i want to automate it, not always on the same place.
It changes by angle, diameter, and length of the following tube.
Is it possible as it always is a cyrcle, to always get the centroid of the inlet/outlet, to set the csys on this place with a normal to the plane?
The Boundary also, always has the same name. So i might could automate it by using java?
Looking forward to hearing from you!
Best regards,
Christian
Chrismaster is offline   Reply With Quote
Old   November 3, 2014, 07:08
kris
kguntur is on a distinguished road
If you know how the co-ordinate system should move, then you can create a co-ordinate system and a motion. Then set it as the managed co-ordinate system in the motion. Then the co-ordinate system moves as per the defined motion.
Hope this helps.
kguntur is offline   Reply With Quote
Old   November 3, 2014, 07:35
Christian
I can get the number of Vertices on this plane.
--> surfaceMeshWidgetSelectController.getNumSelectedVe rtices();
Is there a possibility, to get three points of them, so i can create a c-sys out of this three points/vectors?
would be great, if sb. would know. :-)
Thanks alot!!!!!
Old   November 3, 2014, 08:29
Joern Beilke
JBeilke is on a distinguished road
Just create 3 "Surface Average Reports" for your inlet with the FieldFunction Centroid[x,y,z] to get the position of the center.
For the surface normal just look at:
http://www.cfd-online.com/Forums/sta...al-vector.html
JBeilke is offline   Reply With Quote
Old   November 4, 2014, 05:29
Christian
Thanks for your Answer, I now get the position of the Inlet.
But there is one further problem.
The Inlet gets an extrusion, to reduce reversed flow. So the coordinates, i get are on the extrusion of the inlet. is there a posibillity, to get the coordinates of the "original" inlet?
And further... How do i get the Value of $$Area? Is it like $$Area(b_inlet_1) ??
I was thinking about moving the csys withhin the direction of the normal Vector. Or is there an easier possibility?
Best regards,
Christian
9.04, coordinate system, coordinate transform, java, macro
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
Optimizing the solution of tridiagonal linear systems CCKM Main CFD Forum 14 March 14, 2012 07:40
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Problems with Meshing: Collapsed Cells Emmanuel Resch Siemens 1 July 30, 2007 03:02
