How to assess boundary layer quality
Like Tree1Likes
  • 1 Post By fluid23
Old   March 4, 2015, 02:51
Default How to assess boundary layer quality
MMatt
MMatt is on a distinguished road
Hello guys,
I would like to know how to properly assess if the boundary layer created is correct. At the moment I am using a k-epsilon turbulence model with wall treatment, and I check the wall y+ representation over the body once the simulation is completed.
However, I have seen that you should also take a very close look at how things are modelled around the boundary layer. In my case, I am using a prism layer (5 layers) of 0.005m thickness with a 4m long body at 50m/s.
http://www.computationalfluiddynamic...oundary-layer/
To begin with, what are acceptable values for wall y+ in that case? I hear 30-300, below 5, around 1, it is confusing.
Also are there other tools to make sure my boundary layer is correctly modelled?
Cheers!
MMatt is offline   Reply With Quote
Old   March 4, 2015, 14:55
Matt
fluid23 is on a distinguished road
That depends upon what near wall treatment you are using. The most common (and default) for k-e and k-w is the All y+ wall treatment. This is the most robust option.
That being said, the y+ values you should target vary depending upon who you ask. The best answer I have heard (from CD-Adapco) is that they should be between 1-5 or 30-60 for best results and rarely beyond 120. The split in ranges is a product of using separate near wall and far wall methods and blending them together. In the blending region (5-30) you still get reasonable results, but they are not considered very accurate.
Unless you are doing a DNS analysis you aren't going to be actually modeling hte boundary layer, only approximating it. Y+ is your best bet, although checking your cell quality in the prism layer is never a bad idea. Sometimes y+ is OK but your mesh is crap and results will reflect that.
kuabay likes this.
fluid23 is offline   Reply With Quote
Old   March 5, 2015, 02:13
MMatt
Thank you for your answer.
Yes, I am using the all y+ wall treatment. I have read (I think it was even in the Star-CCM+ help pdf file) that values should be between 30 and 300, but I agree that 300 is definitely too much.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Divide Prismatic Boundary Layer Mesh causes overlapping faces SilentRunner42 enGrid 4 May 4, 2015 03:37
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Grid Independence of Boundary layer Luigi_ Main CFD Forum 0 December 14, 2011 13:42
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
