Extrusion regions not supported with CHT problems? |
March 25, 2015, 05:45 |
Gajendra Gulgulia
Rep Power: 13 |
I created extrusions at inlet and outlet and assigned them as separate regions. The simulation did not run
When I kept the extrusion at inlet and outlet in the same regions as the inlet and outlet boundaries were, it ran. The problem was of steady-state CHT in a fin-louver section, with air as fluid and aluminum as solid Can anyone explain ? |
March 25, 2015, 15:53 |
Matt
Rep Power: 17 |
Good queston. I had issues using extruder on a CHT problem. Although, for me it would freeze the mesher (or at the very least turn a quick mesh operation into many, many hours... I just gave up on it).
This might be a question for your DSE. |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[snappyHexMesh] simple geometry with big problems | Tobi | OpenFOAM Meshing & Mesh Conversion | 6 | October 26, 2012 18:34 |
fluid domain extraction for CHT problems | bhanu1810 | STAR-CCM+ | 3 | May 22, 2011 07:26 |
[blockMesh] Problems of mutiple regions | fw407 | OpenFOAM Meshing & Mesh Conversion | 2 | February 8, 2008 07:54 |
Some problems with Star CD | Micha | Siemens | 0 | August 6, 2003 13:55 |
