angle
Old   May 21, 2015, 01:18
Default angle
protocol is on a distinguished road
I am doing an simulation in 3d i need to specify the flow 10 degree with respect to x axis if i change flow direction specification to degrees i get phi theta and psi can anyone tell me what to give for these values
protocol is offline   Reply With Quote
Old   June 2, 2015, 10:17
Matt
fluid23 is on a distinguished road
Are you talking about boundary conditions? Why not just set the vector components?
fluid23 is offline   Reply With Quote
Old   June 2, 2015, 10:56
Default angle
I wanted to learn more about these
Old   June 2, 2015, 11:34
Matt
They are Euler angles. It depends on the rotation convention you define, but they correspond to angles about the cartesian axes. I assume you are familar with Euler angles, no? Check out the help docs on the subject, they should clear things up for you.
User Guide > Modeling Physics > Modeling Flow and Energy > Values Reference > Boundary Values > Flow Angles
Dynamic contact angle calculation in multiphaseInterFoam rajeshchem OpenFOAM 3 December 23, 2022 14:00
Dynamic contact angle raj kumar saini Fluent UDF and Scheme Programming 0 October 13, 2014 02:18
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Normal vector, slope and aspect angle g_niro Main CFD Forum 0 February 2, 2011 17:24
Theoretical background of formula for dynamic contact angle in interfoam sebastian_vogl OpenFOAM Running, Solving & CFD 3 June 22, 2009 12:25
