Flow-split outlet
Old   June 9, 2015, 09:39
Default Flow-split outlet
Jacopo
jano5889 is on a distinguished road
I have three horizontal tubes forming a T, with three different diameters. I have velocity inlet but I don't know the outlet's pressures. What happens if I set the outlets as Flow-Split Outlet, setting both split ratio to 1? In what way does the fluid split itself in this case?
Thank you very much
jano5889 is offline   Reply With Quote
Old   June 16, 2015, 05:36
Jacopo
Please answer me if you can!!! It is very important
Old   June 29, 2015, 23:03
me3840 is on a distinguished road
I don't think you can do this, the flow split outlets are formulated to conserve mass. The code will probably not allow you to specify them both as 1.
me3840 is offline   Reply With Quote
Old   July 9, 2015, 11:42
Kevin
kirrer is on a distinguished road
Maybe bringing up an old thread, but I would not use flow split outlets. I think what you mean, is that for each outlet, the flow should be 50% of the inlet flow. In this case, set one outlet to a mass flow inlet, calculate 50% of the mass flow, and apply the mass flow as a negative value (ie, 1 kg/s in means -0.5 kg/s on that mass flow inlet, so it is effectively an outlet).
Then, set the other outlet to Pressure out, and through mass conservation, you will automatically get 50% of the flow at that outlet as well.
kirrer is offline   Reply With Quote
Old   July 9, 2015, 12:52
Jacopo
Thank you very much!!!
Old   July 16, 2015, 08:39
Gajendra Gulgulia
ggulgulia is on a distinguished road
Hi Jano
If you are looking to get a specified fraction of mass flowing through each tube, then flow split outlet is the best option, the sum of fraction of mass flowing through each outlet being 1.0
You must also specify the guage pressure by opening the solver manager and applying target pressure at specfied boundary (here you have to input the coordinates of any one point lying on the boundary)
ggulgulia is offline   Reply With Quote
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump Zev Xavier FLUENT 3 May 9, 2016 06:42
open channel flow BC pressure outlet Ema40 Fluent Multiphase 0 January 17, 2015 07:21
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Flow Split Setup Question ed FLUENT 1 February 16, 2007 16:55
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
