August 17, 2015, 10:27 |
Field Function Results Not Correct
Matt
Rep Power: 17 |
Can anyone explain to me why some of my field functions are not getting calculated properly? I have a field function, call it fz, that is of the form:
42571.79*$massflowReport*$massflowReport-95.09*$massflowReport The $massflowReport is a mass flow report (as you might have guessed). It returns a value of 0.0446 lbm/s. Which should return a value of fz equal to ~80.462. However, if I setup a maximum value report to get the value of fz (which is constant everywhere) it returns a value of 0.01016. I am at a loss to explain this. Any advice? |
August 17, 2015, 12:15 |
Matt
Rep Power: 17 |
Solved...
It turns out that field functions always use the SI value of whatever report you call. So what was happening is that the coefficients of the function I gave assumed that mass flow report was in lb/s but it was actually in kg/s. After re-deriving my coefficients in SI uints, the values are being calculated correctly. |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
