How am I able to get the values of mass flow rate out of each of my outlets? |
December 1, 2015, 10:32 |
Alan
Rep Power: 10 |
Hi, first of all I just want to say I'm a complete newbie and this is my first encounter with CFD software for my uni project.
Basic details on my simulation/problem: I have a 20m long sootblower lance (essentially acting as a distributing manifold) with 12 nozzles equally spaced along the length leading up to a closed end. (see sootblower lance figure for an simplistic example). Now I've run my simulation (with a known mass flow rate at the input) and set all of my nozzles as pressure outputs. My results for pressure and velocity in the manifold seem accurate but I am just wondering if there is a way I can select my outlets (as a plane or face or something) and see the exact mass flow at each of them. I can go into far more detail or upload some images of my simulation if needed...thanks for any suggestions! |
Calculating mass flow rate at multiphase flows | Kuslo187 | OpenFOAM Post-Processing | 1 | August 21, 2015 18:11 |
Split Mass Flow Rate in ANSYS CFX | ashtonJ | CFX | 2 | July 9, 2014 03:08 |
Periodic channel flow with time dependent mass flow rate | QBeast | FLUENT | 3 | May 10, 2013 13:14 |
How to define a fixed velocity for a given mass flow rate on inlet | mqasimali | FLUENT | 2 | April 12, 2013 17:24 |
mass flow rate error | Masood | FLUENT | 0 | May 22, 2005 00:32 |
