starCCM+ to OpenFOAM mesh
Old   January 13, 2016, 10:55
Default starCCM+ to OpenFOAM mesh
stefano zinna
giordy is on a distinguished road
Hi All,
I am interested in the transferring between starCCM+ and OpenFOAM meshes. I did successfully for simple geometry but I got issues for complex ones. I read in an old Thread that:
"Also, the polymesh that Star creates is not always great quality. The solver can handle it because it just turns off those poor quality cells (just doesn't solve them) if they start to be a problem."
I exported a ccm mesh that it was running in starCCM+. When I used ccm26toFoam to import in OpenFOAM I get very bad cell quality and wrong oriented faces (by checkMesh). I tried also to import the mesh from starCCM+ to Fluent and the mesh check (in fluent) shows similar issue (for orthogonal quality and aspect ratio). Hence I was wondering if what I read in the old thread is true and If there is away to transfer a good quality mesh from starCCM+ to OpenFOAM.
thanks!
regards,
Stefano
giordy is offline   Reply With Quote
[Commercial meshers] About the Commercial and Closed Source Meshers discussed here wyldckat OpenFOAM Meshing & Mesh Conversion 3 July 22, 2020 22:09
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 07:18
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
