Wall Y+ value in the buffer region
Old   February 24, 2016, 18:50
Default Wall Y+ value in the buffer region
Kamal Bisht
Bisht is on a distinguished road
Hi, I am bit confused about the wall Y+ value requirement for Realizable k-epsilon model. In order to resolve the viscous sublayer, it should be below 1 and for application of wall function it should be above 30.
But what will be the accuracy of the result for y+ value in range of 5-25,i.e buffer region.
From the Star-CCM+ user guide, I got to know about the Two layer all y+ wall treatment which basically switched between high Y+ and low Y+ wall treatment according to Y+ value. But what will happen when y+ value is between 5-25? Can Realizable k-epsilon model resolve it efficiently?
Bisht is offline   Reply With Quote
Old   February 26, 2016, 07:35
Blanco
Blanco is on a distinguished road
Short answer :no ;-) none of the rans turbulence models is appropriate in the buffer region, even if sometimes the high re approach could give good results also when y+ is as low as 11-15, but this is very case dependent.
Blanco is offline   Reply With Quote
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
How I can introduce my power heat (W) in chtMultiRegionFoam? aminem OpenFOAM Pre-Processing 32 August 29, 2019 02:23
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
