March 16, 2016, 01:39 |
New to StarCCM+
Henry
Rep Power: 10 |
Hello there, I am new to StarCCM+ and I would like to gather some inputs regarding the work I am doing and the challenges I am facing.
The results I am pursuing is getting pressure and temperature profile of a subsea pipeline which is experiencing natural convection cooling. The pressure change I am expecting is the pipe losses. Firstly I had create a pipe and assigned a material to the model in Solidworks. It is a simple 500m pipe with a assigned thickness. After which I had sent it over to starCCM+ by exporting as a parasolid. <a href='http://postimg.org/image/y88igkd7h/' target='_blank'><img src='http://s22.postimg.org/y88igkd7h/Pipe_Picture.jpg' border='0' alt="Pipe Picture" /></a> Over at StarCCM+ I proceeded to create the meshing models and I had chosen.... <a href='http://postimg.org/image/7n8dqje29/' target='_blank'><img src='http://s8.postimg.org/7n8dqje29/Surface_Meshing.jpg' border='0' alt="Surface Meshing" /></a> After which I had adjusted the Mesh size to be "0.5" Physics Model: Phase 1 Physics Model: Methane, (CH4) was chosen as the gas <a href='http://postimg.org/image/6oqtimdoj/' target='_blank'><img src='http://s13.postimg.org/6oqtimdoj/Phase_1_Model.jpg' border='0' alt="Phase 1 Model" /></a> Phase 2: Pentane (C5H12), Hexane, (C6H14) and Water (H2O) <a href='http://postimg.org/image/6ilw5e2xf/' target='_blank'><img src='http://s21.postimg.org/6ilw5e2xf/Phase_2_Model.jpg' border='0' alt="Phase 2 Model" /></a> Mass Species Fractions was not tempered and set at [0 0 0] for the 3 components at initial value. Also, I had adjusted the surface tension to be 24dyne/cm <a href='http://postimg.org/image/q1hy4pt5p/' target='_blank'><img src='http://s30.postimg.org/q1hy4pt5p/Surface_Tension.jpg' border='0' alt="Surface Tension" /></a> When the Meshing Models are completed, I proceeded to split the model by parts and assigning it into 3 components: Inlet, Outlet and Wall <a href='http://postimg.org/image/shgq7652j/' target='_blank'><img src='http://s17.postimg.org/shgq7652j/Splitting_by_Parts.jpg' border='0' alt="Splitting by Parts" /></a> Note: The pipe is hollow with open ends. Assigning them into regions Inlet would be assigned to: Velocity Inlet Outlet: Pressure Outlet Wall: Wall The values are put as default except the velocity is set at 10m/s and pressure to be 1.5 atm Problems: A floating point exception hasoccured: Floating point exception [ invalid operation]. The specific cause cannot be identified. Please refer to troubleshotting section of the User's Guide. Context: star.segregatedflow.segregatedflowsolver For this problem, I had a problem finding the "Segregated Time Step" in the physics continua. After inputting these values, I could not run the simulation because it says: <a href='http://postimg.org/image/x6yfubzf7/' target='_blank'><img src='http://s29.postimg.org/x6yfubzf7/sum_of_mass.jpg' border='0' alt="sum of mass" /></a> However I had adjusted the species mass fractions for initial conditions, Inlet and outlet region. However it does not solve the problem [img=http://s23.postimg.org/g6dqxpw5z/Species_mass_fraction_constant.jpg] I apologize for the lengthy post and any type of inputs are most welcome!! |
Meshing for StarCCM | sjohnson | Main CFD Forum | 2 | June 3, 2010 08:10 |
importing cad geometry, starCCM 64bit?? | syd | STAR-CCM+ | 3 | March 30, 2010 07:17 |
[Other] Problems with starccm mesh | AndTen | OpenFOAM Meshing & Mesh Conversion | 1 | February 23, 2010 04:43 |
Importing new design in starCCM | bramv101 | STAR-CCM+ | 0 | October 1, 2009 08:43 |
Meshing Errors in Starccm | Josh Kempenaar | Siemens | 2 | November 30, 2006 08:14 |
