atmospheric boundary condition
Old   July 12, 2016, 03:06
Default atmospheric boundary condition
Almond Wong
BakedAlmonds is on a distinguished road
Can anyone teach me how to set up an atmospheric boundary condition for the initial condition for starccm+.
For example, the velocity will not be a uniform value but rather goverend by the atmospheric boundary condition formula.
BakedAlmonds is offline   Reply With Quote
Old   July 12, 2016, 10:53
Wade
wadeellis is on a distinguished road
The way I usually do it is to define the boundary as a velocity inlet. Then, if I know what the velocities will be at each point, I define the velocities using a table. To do that, go to the boundary, select velocity inlet-> physical values -> velocity magnitude. Then you can select table under 'method'. You then need to define a table based on radius, time, or x y z coordinates. You can do this under tools. This will then be the velocity for each point throughout the simulation.
wadeellis is offline   Reply With Quote
Old   July 12, 2016, 13:02
Almond Wong
THANK YOU for the guidance!!!
What is the format for the table?
I have a velocity profile which varies with height. This can be plotted using excel so i can get U vs z but what about x and y?
Old   July 12, 2016, 13:05
Wade
I do 2D simulations mostly, so I have one column as radius in meters starting at 0, then I define the other column as the velocity. This is for a v(r) table. I have not done a v(x,y,z) table before, but I assume you would just have columns for each dimension (x, y, z, and velocity).
Old   July 14, 2016, 09:02
Almond Wong
Hi, how did you imported the table into starccm+?
I did: region > *region that i want* > physics values > velocity magnitude > *change to table (x,y,z)* > then i am stuck at this point.
I further into table x,y,z but there is nothing to select for table,table: data
Old   July 14, 2016, 09:58
Wade
To create or import a table, go to the tools section. Under tables, select the type of table you want (in this case x,y,z). Then you can either create one in Star CCM+ or import one from a file. Make sure that the coordinates and velocity values are in columns as you will select which column contains x, y, z, and velocity.
Old   July 14, 2016, 15:17
Almond Wong
thanks for the reply!!
In any case, if anyone else want to know how, can refer to this thread http://www.cfd-online.com/Forums/sta...ng-tables.html
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
p_rgh outlet boundary condition for atmospheric simulation Raphael_Santos OpenFOAM Running, Solving & CFD 0 September 9, 2015 08:52
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Velocity profile boundary condition Tuca FLOW-3D 1 April 23, 2013 12:02
