Types of mesh
Old   July 15, 2016, 10:42
Default Types of mesh
Andrea
Andrrrew is on a distinguished road
Greetings,
Just out of curiosity, what kind of meshing models do you usually use? and why?
Andrrrew is offline   Reply With Quote
Old   July 15, 2016, 14:26
Kevin
kirrer is on a distinguished road
Polyhedral mesh in most cases (with thin mesher/embedded thin mesher/extruder as needed). Why? It's based on a tet mesh and is easy to automesh many different geometries with good accuracy. Also for the majority of simulations, having a hex mesh in the core is not crucial so I can live with the poly's lack of orthogonality (mostly liquid/solid simulations). If I was working with air simulations, and core motion/turbulence was important, I might stick to trimmed or directed mesh, depending on the geometry to be meshed.
kirrer is offline   Reply With Quote
Old   July 17, 2016, 00:05
Lane Carasik
lcarasik is on a distinguished road
Originally Posted by Andrrrew View Post
Greetings,
I primarily use the trimmer, prism layer, and extruder meshers. I find them to be the most intuitive and give me the most control over the mesh. Additionally, I personally find (again OPINION) the refinement regions to work better using the Trimmer mesher.
Also, I use the directed mesher when I can.
lcarasik is offline   Reply With Quote
Old   July 17, 2016, 02:43
kevin alun
marmot is on a distinguished road
Trimmer, prism layer, trying to get into parts based meshing,
Agree with electronics cooling, or CHT problems go with polyhedral, thin mesher most likely
But trimmer / polyhedral its like do you use oil or acrylic paints, they both create the painting,
The idea that polyhedral is better for flow that is not aligned to any coordinate because it is less diffusive than a trimmed mesh is for me marketing material but you can always find at least one case to back up marketing material.
marmot is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
mesh types in pipes Bo Busk Jensen Main CFD Forum 2 August 2, 2002 11:11
