Negative volume cells
Old   January 26, 2015, 14:41
Default Negative volume cells
nbons is on a distinguished road
Hi all,
I'm building a 2D simulation to analyze a vertical axis wind turbine. I'm trying to create an interface between a circular rotating region and an outer free-stream region. The meshing is good...when I run mesh diagnostics it has no negative volume cells. However, when I run the simulation, it gives an error that there are negative volume cells. I assume that this is from the interface initialization because the negative volume cells weren't there before. I've tried changing the intersection tolerance on the interface, but it only changes the number of negative volume cells created. Does anyone have any suggestions on how to fix this or information regarding creating intersections like this?
Much appreciated!
nbons is offline   Reply With Quote
Old   January 27, 2015, 01:57
kris
kguntur is on a distinguished road
Hi
What type of mesh are you using? polyhedral or trimmed? If using poly, try to create a conformal mesh.
if using trimmed, then create same size mesh on either side of the interface to get a better interface. You could also try and align the mesh so that the mesh could be nearly conformal.
Hope that helps!!!
kguntur is offline   Reply With Quote
Old   January 27, 2015, 12:18
I'm using a trimmer mesh and I have specified the same mesh size on both of the boundaries. I tried aligning both of the meshes to the origin (center of the turbine) but it yielded the same result. What exactly is a conformal mesh?
Also, I've included pictures of the overall mesh of the two regions, the mis-aligned cells on the interface boundary, and the resulting negative-volume cells from the interface initialization. If you have any more suggestions from seeing the pictures, please let me know.
Thanks!
interface, intersection tolerance, negative cell volume
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[snappyHexMesh] SnappyHexMesh collapse at the boundaries giving negative volume cells risku9 OpenFOAM Meshing & Mesh Conversion 2 September 8, 2014 05:51
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 05:25
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
