Oscillatory flow in a pipe
Old   June 18, 2009, 05:13
Default Oscillatory flow in a pipe
thomas
tom-uk is on a distinguished road
I would like to simulate an oscillatory flow crossing a pipe.
I wonder if I have to use periodic boudaries condition (inlet/outlet) or not?
Also can I use a user fonction to define my flow inlet (like: sin(cst*$Time) )?
Thanks in advance.
Tom
tom-uk is offline   Reply With Quote
Old   June 18, 2009, 08:10
Aroon
vishyaroon is on a distinguished road
Hello Thomas,
I have used a time varying inlet velocity before using the sine function defined as a separate field function and calling the field function as the BC. However in my case, the velocity was always positive and I imposed this velocity as an inlet BC. My function was of the form
V = V0 (2 - sin(w*t))
It worked well. However I have not tried a case with a function where teh flow could go negative, like
V = V0 sin(w*t).
vishyaroon is offline   Reply With Quote
Old   June 18, 2009, 09:00
thomas
Many thanks for your answer. I am using a User field fonction now.
Yes in my case the velocity can be negative. So may be I think I have to use periodic BC but I don't really understand how periodic BC work.
Someone could give me information regarding Periodic BC.
Thanks.
Old   June 18, 2009, 10:11
Aroon
Hello Tom,
To use periodic BC you have to select the two boundaries that are periodic and then define an interface between them. This interface then has to be defined as Periodic and Fully Developed.
But using the periodic BC in STAR CCM+ gives you periodicity in space, not in time.
Old   June 19, 2009, 05:05
thomas
Hello Aroon,
Many thanks for these information.
In fact, for me periodicity in space is not really clear. I don't understand very well of what it consists.
Thanks.
Simulating fully developed flow in a pipe Tim Donohue CFX 1 November 20, 2007 20:24
some weird results about a simple pipe flow: Ning FLUENT 2 March 11, 2007 13:23
Flow through circular curved stationary pipe R.Sripriya Main CFD Forum 0 May 13, 2005 06:07
flow in pipe with momentum and energy source Atit Koonsrisuk CFX 3 March 29, 2005 16:58
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
