the 6-DOF embedded motion example ?
Old   September 9, 2009, 23:19
Default the 6-DOF embedded motion example ?
Liu
uiui is on a distinguished road
anybody have the example of 6-DOF embedded motion. pls explain it in detail or kindly send me the .sim file. Thanks very much...
uiui is offline   Reply With Quote
Old   September 11, 2009, 00:50
Liu
nobody knows? this is all i can find from manual and release notes:
This latest version of STAR-CCM+ extends the recently introduced DFBI modeling capabilities by introducing the ability to simulate the movement of solid bodies using either embedded motion or mesh morphing. By enclosing the body to be studied in a spherical or cylindrical sub-domain, the embedded motion technique allows the simulation of extreme levels of rotation such as lifeboats falling into water or shipping containers slamming into the ocean. While the sub-domain is free to rotate without limitation, the rotation and translation of the outer fluid domain may be limited; ensuring robustness of solution without having to resort to time and resource consuming re-meshing techniques.
Embedded motion (the moving body is enclosed in a sphere or a cylinder and attached via the sliding interface to the remaining part of the grid)
The 6-DOF Embedded Motion model involves a floating object in a sphere. The simulation includes a sliding internal interface between the sphere and the rest of the mesh, and the sphere rotates. This approach allows for larger rotating angles while creating a fine mesh only within the sphere. This is an alternative to a higher resolution for the entire mesh, which would be more computationally expensive.
So the question is:
1. the subdomain should create a region seperately or inside the whole region?
2. how to define a sliding internal interface.
3. how to define the relation between rigid body and sliding interface?
I am stuck on the problem and appreciate any idea from you. Thanks in advance !
Old   October 8, 2010, 09:35
Ale_galleria is on a distinguished road
Up. I have the same dubs. Help me, thank you.
Ale_galleria is offline   Reply With Quote
Old   May 5, 2011, 19:21
Default DFBI Emebedded Motion
Naimish Harpal (MS Aerospace Engr)
naimishharpal is on a distinguished road
Ans: Both the domains must belong from two separate regions. The spherical region (which includes boat...) has to be specified with 'DFBI Embedded Motion', whereas the outer domain with Stationary. Since, common fluid passes, same Physics1 has to selected for both regions.
Ans: The sphere of has to be transformed into in-plane interface. I'm not sure about this.
Ans: Once you define your rigid body as 'DFBI', it will behave as per DFBI Embedded Motion, and I think it doesn't require any 'relation' with interface. The 6-DOF should calculate the motion automatically, and the corresponding fluid properties will be exchanged at the interface.
I might be wrong above. Please share your review and valuable comments here.
Thanks,
NHarpal
So the question is:
naimishharpal is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
tank motion on boat Tim FLUENT 0 May 23, 2007 11:50
large scale mesh motion sb FLUENT 1 April 27, 2007 22:23
Six dof UDF Dr. John Anttonen FLUENT 0 February 22, 2002 14:47
