Does the Star-CCM+ solver support structured grids? |
December 11, 2009, 06:21 |
Peres
Rep Power: 16 |
Hi there
Does anyone know if the Star-CCM+ solver accepts a structured (single or multiblock) volume mesh. I've managed to export an unstructured volume mesh from ICEM CFD into Star-CCM+, but not a structured one. I can't find any clear info on this in the Star-CCM+ documentatation. Thanks! |
December 13, 2009, 15:10 |
Joern Beilke
Rep Power: 20 |
You can load any mesh into ccm+. You only have to convert it into one of the supported formats. CCM+ then treats all meshes as unstructured (face based).
December 14, 2009, 07:33 |
Peres
Rep Power: 16 |
You seem to agree that Star-CCM+ only supports unstructured grids, right?
December 14, 2009, 09:50 |
TonyD
Rep Power: 17 |
In a way you can say it supports them, however you need to convert...
December 15, 2009, 03:26 |
Peres
Rep Power: 16 |
Ok, thanks for clarifying :-)
January 7, 2010, 01:22 |
chris morley
You can import single block or multi-block plot3d files, those are structured grids.
January 7, 2010, 09:53 |
Peres
Rep Power: 16 |
Okay, although I have by now found papers stating that Star-CCM+ works on unstructured grids only and ICEM doesn't allow export of structured grids when Star-CCM+ is chosen as solver.
January 11, 2010, 09:25 |
struct/unstruct & grid vs solver
#8 | |
Subhadeep
Rep Power: 16 |
BUT physically your grid used is still structured with respect to location of the grid points and the 3D volumes. You are still getting nice cubes of volume from your structured grid. If this was your original goal to have the structured grid for computational domain then stick with it. All that is happening is the format change in data storage. Your structured grid is not being converted to a different unstructured grid. This is true for all unstructured solvers. Most commercial codes are unstructured solvers. Only in house research codes are structured solvers. There only way to read in is structured grids like Plot3D format. |
January 12, 2010, 02:57 |
#9 |
Peres
Rep Power: 16 |
Hi Subhadeep
Thanks for the discussion. :-) I think we agree over-all on the content, although not on definitions :-). As far as I know, the conventional definitions for structured/unstructured grids (or solvers) are dependent on the way the data is stored, not directly on spatial distribution:
structured grid |
multigrid solver in stretched/nonuniform grids? | Lewis | Main CFD Forum | 3 | September 26, 2003 11:26 |
Structured or un-structured solver | Jérémy D | Main CFD Forum | 1 | November 5, 2002 12:33 |
Setting a B.C using UserFortran in 4.3 | tokai | CFX | 10 | July 17, 2001 16:25 |
ICCG Solver for Unstructured Grids | Bryce Sharman | Main CFD Forum | 2 | January 11, 2001 12:02 |
matrix solver about block structured grid | young min, Sohn | Main CFD Forum | 1 | July 11, 2000 19:35 |
