Negative Heat Transfer Coefficients
Like Tree1Likes
  • 1 Post By yugo_wen
Old   May 24, 2010, 19:20
Default Negative Heat Transfer Coefficients
Matt
Archangel2424 is on a distinguished road
Hi all,
I am modeling air flow over a vehicle. Some portions of the mesh such as tires, controllers, and motors are generating heat so I have boundary conditions at steady state temperature operation. When it appears my system has converged, I am seeing some areas of negative heat transfer coefficient. They are patchy at best but concentrated in symmetry on both sides. Can someone help me with this?
Archangel2424 is offline   Reply With Quote
Old   May 27, 2010, 17:19
Default Re
Yugo Wen
yugo_wen is on a distinguished road
h=q/(T_surface-T_infi)
The reason you got negative h may be is that your reference temperature is set too high. So check your reference temperature.
If the heat is from the surrounding to the surface meaning that the surface is cold, then h is negative.
Hope this is helpful...
kev11 likes this.
yugo_wen is offline   Reply With Quote
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
negative heat transfer coefficient Sigrid Andreae CFX 1 February 26, 2005 07:13
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
