Removing Invalid Cells?
Old   June 8, 2010, 08:27
Default Removing Invalid Cells?
syd
Mattia
syd is on a distinguished road
Hi everyone!
I have a problem: I'm simulating a sailboat, but, everytime I mesh it, there's always some invalid cells (in the mast), no matter how small I choose the base size and local meshing parameters.
I can't modify the CAD files which I am importing, so I guess there's no way I won't have some invalid cells...
Now, if I try to run a solution after removing these invalid cells, will it diverge?
Thank you all!
syd is offline   Reply With Quote
Old   June 8, 2010, 14:18
f-w
f-w's Avatar
f-w is on a distinguished road
Only one way to tell ... but make sure you are not removing too many. When you do this, you are basically changing the geometry, since the neighboring cells' faces get symmetry planes assigned to them.
On a side note: you should be catching and correcting bad cells at surface mesh level, so they won't make your life harder later on. You can do this manually or automatically with the surface repair tool (look it up in the manual).
f-w is offline   Reply With Quote
Old   June 8, 2010, 17:45
syd
Mattia
thanks.
anyway, I removed few cells, let's say a dozen more or less...
I'll also try to wrap the surface before remeshing, I want to see if this helps...
Old   June 8, 2010, 18:09
Vinicius Girardi
Vinicius is on a distinguished road
You can turn on the cell quality remediation in the physics continua and remove the invalid cells with a rigth click on the region, and choosing remove invalid cells option.
Vinicius is offline   Reply With Quote
Old   June 9, 2010, 13:00
f-w
f-w's Avatar
From past experience, cell quality remediation doesn't always work (especially on invalid, rather than poor-quality cells); plus, it slows down your simulation because after each iteration, computations are made to find these cells.
Old   July 6, 2010, 09:45
abdul099 is on a distinguished road
In my experience, a lot of problems with invalid cells are caused by a shitty CAD geometry.
As f-w said, you can try to repair the surface before generating a volume mesh. In my experience, it is the best to do it manually (if the errors are not too much), and to start with the imported surface. If it has a good quality, the surface remesher has less problems and the overall mesh quality could be increased. Got to "Representations", Right-click on "Imported surface", choose "Repair Surface". The use of the surface repair should be explained in the tutorials.
If there will still be a lot invalid cells, you should go a step back and check if your geometry is suitable for CFD and your mesh settings are suitable for this geometry. You should make sure, there are no unimportant small geometry features and/or mesh settings are appropriate to capture all geometry feature.
Best regards
abdul099 is offline   Reply With Quote
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
