Error in the solver !!! what does this mean...
Old   September 3, 2010, 03:07
Default Error in the solver !!! what does this mean...
Elena Cortin
eleazar is on a distinguished road
Hello
does anyone knows what is this error?
server error: a floating point exception has occured: floating point exception [invalid operation]. The specific cause cannot be identified. Potential causes may include : (a) solution divergence due to poor mesh quality, crude initiliazation, etc, or (b) errors in the user-defined code or field fuctions.
thanks
eleazar is offline   Reply With Quote
Old   September 3, 2010, 06:15
bengy is on a distinguished road
-use smaller time-step in your simulation (it have to work but time of computation will be longer)
-you can solve this problem on numerical way (underrelaxation factors etc.)
-improve mesh quality
-and/or chack (also possible) eg.capital font, sign (_ / -) in name of field function
regards
bengy is offline   Reply With Quote
Old   September 3, 2010, 08:34
Elena Cortin
regards
well i do not have any sign (_\ etc)
i activate the ramp method to linear ramp
and apply a courant number 2
the mesh is ok
any other idea>????
thanks
Old   September 3, 2010, 10:04
courant number should be between 0.5 - 1.
let's try with smaller time step
Old   September 4, 2010, 03:15
Elena Cortin
well i am having the same error
i am trying to do a transonic simulation of a missile model
and i follow the example but in 3d model, can i find any pre file with an axable like this????
i believe this is better option.
please any help on that
Old   September 4, 2010, 05:10
how large is your time step?
how many elements your mesh have?
where did you prepare mesh? (star-ccm+ or external soft?)
what kind of mesh do you have?(conformal or non-conformal?)
you have to sent more info about your simulation (physical model, expected value of solution-temp, velocity ec)
Old   January 12, 2011, 07:42
Red face
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
Divergence of the solution is the situation where cell residuals increase from one iteration to another. If left unchecked, this will eventually result in a floating point exception being reported.
I found it in the help of the software
siara817 is offline   Reply With Quote
Old   January 15, 2011, 08:05
abdul099 is on a distinguished road
Just go to the solver manager and tick the box "Temporary storage retained". This will prevent the solver from deleting temporay values when a iteration is complete.
With this option, you will have more field functions available, e.g. residuals, gradients etc...
So create a scene and check the residuals, it can give you an evidence where the problem could be located.
abdul099 is offline   Reply With Quote
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
Getting too many iterations by velocity solving (aborting). Changing U - Solver? suitup OpenFOAM Running, Solving & CFD 0 January 20, 2010 07:45
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
Setting a B.C using UserFortran in 4.3 tokai CFX 10 July 17, 2001 16:25
