how to setup pressure boundary conditions?
Old   November 17, 2010, 20:43
Post how to setup pressure boundary conditions?
gary
bioman6666 is on a distinguished road
Hello
I want to use star-ccm to simulate water flowing in a duct. One side of this duct is connected with a very larger top-openned reservoir and the other side is applied with a negtive pressure [like vacuum pump] to suck water out. What kinds of pressure type should I define in inlet side at reservoir top face and outlet side ?
Thank you !!
Gary
bioman6666 is offline   Reply With Quote
Old   December 14, 2010, 10:39
Default reply
wenjiewang
hx_wwj is on a distinguished road
inlet pressure outlet
outlet pressure outlet
并且需要预定义流速,否则反流比较严重
hx_wwj is offline   Reply With Quote
Old   March 23, 2011, 14:14
Mahbub Islam
mahbub03 is on a distinguished road
Inlet- Velocity Inlet
Outlet: Pressure Outlet
Most convenient BC for duct flow.
mahbub03 is offline   Reply With Quote
Old   March 26, 2011, 23:55
gary
So, can I set the inlet side with 1 atm total pressure as a boundary condition; and 0.95 atm static pressure pressure as outlet condition ? [reference pressure = 0 atm]
As to the pre-defined velocity, should I set it in the initial condition?
Thanks !!
Old   April 1, 2011, 19:09
ara
ara1362 is on a distinguished road
You can either do mass flow inlet or velocity inlet.
for outlet use stagnation inlet and choose a negative pressure.
pressure outlet does not work as well with negative pressures.
as far as initial conditions go: they are good for the first initial guess.
use the inlet conditions on the inlet boundary with no pressure.
set something for the reference pressure, i dont think ccm+ likes 0 reference pressure that much and adjust your outlet pressure accordingly.
ara1362 is offline   Reply With Quote
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
Pressure far field boundary conditions not respected?! Bedotto FLUENT 4 August 17, 2010 04:42
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
How to Define Pressure Boundary Conditions? Sheenu Main CFD Forum 4 May 12, 2000 12:52
