Rigid Body motion??
Old   April 25, 2013, 04:54
Default Rigid Body motion??
Arun Krishnan.L.H
arun7328 is on a distinguished road
Dear All,
I have done the boat tutorial and followed the same procedure to define DFBI for a cylinder on free surface. The fluid domain is 40x10x3 and origin of the cylinder is at 0,0. Free surface is also initialised at 0,0.
Can I impart simple harmonic oscillations to the cylinder using a field function and reference the field in the initial velocity tab of DFBI? When i do it the whole domain seems to be moving. It was done successfully using translation, morphing and overset mesh.
I also tried to define a wave at the inlet to see the free motion of the cylinder. Again the whole domain was moving.
I have created a new cartesian coordinate at 0,0 which is referenced in initial coordinate of DFBI.
Can you please give me suggestions. ?
Regards
Arun
arun7328 is offline   Reply With Quote
Old   April 27, 2013, 11:15
KHB
lava12005 is on a distinguished road
I might not get your question. But if you can perform successfully with morphing/overset, then you can do the same when there is wave right?
If no morphing/overset then I believe the whole domain will move since the mesh is fixed w.r.t. the cylinder.
lava12005 is offline   Reply With Quote
Old   April 27, 2013, 12:30
Arun Krishnan.L.H
Thanks a lot Lava. I was also thinking the same. Tried every possible thing i could. I thought this would work just like the boat tutorial. There the mesh is fixed to the boat, but when we it experiences an encountering wave, it heave and pitches.
I am going to a seminar by CD-adapco on tuesday will clear the doubts with them. If you have time please could you check my thread 'hydrodynamic force?' which was posted a few days back. If you have any idea could you please give me some help.
Thanks
Regards
Arun
Old   April 30, 2013, 02:45
Default star ccm+
yanbin
yanbin is on a distinguished road
I have met the same problem. The whole domain will be moving with the DFBI module. I have been trouble for this question for two weeks.
yanbin is offline   Reply With Quote
Old   April 30, 2013, 02:47
yanbin
how can I check the mesh is fixed w.r.t. the cylinder? When generating the volume mesh, the cylinder and whole domain are meshing at the same time.
Old   April 30, 2013, 03:39
KHB
Hi Yanbin,
If you are not using any Overset or morphing mesh, then the whole mesh will be fixed, it means the whole domain will move with the cylinder.
Depending on what you want to achieve this is still fine (example the boat tutorial domain is moving with the boat). You just need to be careful regarding the mesh resolution at the boundary (say the free surface resolution getting worse due to the moving boundary).
There are overset and morphing tutorial, so you can see their difference.
Good luck!
Old   April 30, 2013, 03:48
yanbin
Hi Yanbin,
Good luck!
Thanks for your advice!I'll try and I will consult you if there are other problems.
Old   June 4, 2013, 01:11
Default a fatal error has been detected by the Java Runtime Environment.
yanbin
Hello. I have met a problem that the star ccm+ program exited during the running and a notepad file produced. It shows that a fatal error has been detected by the Java Runtime Environment. What's wrong with my operation for the star ccm+ program? Can you help me?
Old   June 4, 2013, 04:31
Arun Krishnan.L.H
Do you have any msgs in your output window? Could you please elaborate a little? your problem and how you set it.
Thanks
Regards
Arun
Old   June 13, 2013, 03:37
yanbin
I'm so sorry for being late. There is a log file named "hs_err_pid720.log".
The main point of the log file is listed below,
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000007feed0e98af, pid=720, tid=1948
# JRE version: 6.0_35-b10
# Java VM: Java HotSpot(TM) 64-Bit Server VM (20.10-b01 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [vtkCommon.dll+0x498af]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Thanks for help
Old   July 9, 2013, 09:05
Default zero acceptor cells in overset region
  #11
yanbin
Have you met the problem "zero acceptor cells in overset region" ?
Yan Bin
Thanks
Regards
Arun
Old   July 9, 2013, 09:44
KHB
Maybe your overset mesh has a low resolution somewhere and they meet with a high background mesh resolution?
The overset and background mesh should have similar mesh size around the intersection area..
Old   July 9, 2013, 23:45
  #13
yanbin
Thank you for your advice! I am trying!
Old   November 13, 2013, 09:15
MB
matzbanni is on a distinguished road
Did you solve it? I´m facing the same problem here...!
matzbanni is offline   Reply With Quote
Old   November 13, 2013, 23:42
yanbin
Yes, I have solved the problem by the advice of lava12005!
Old   November 14, 2013, 02:19
MB
Found the problem as well, but it wasn't a resolution issue...
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Rigid body motion error when restarting a terminated FSI simulation lingdeer ANSYS 1 May 19, 2013 01:40
CEL code for simulating the equation of motion of a vibrating rigid body mohamadaliv CFX 11 October 19, 2011 04:30
Using solidBodyMotion for rigid body motion L1011 OpenFOAM 4 July 5, 2011 04:59
rigid body motion antonello FLUENT 3 July 28, 2004 03:25
