NREL Phase VI Rotor Validation
Old   April 25, 2011, 17:21
Default NREL Phase VI Rotor Validation
John
nomad is on a distinguished road
Has anybody tried to validate this experiment in STAR CCM+? Papers and full documentation can be found at :
http://wind.nrel.gov/amestest/
And if so, were you able to match the pre-stall cases at less than 10m/s of wind velocity?
The case in particular is at 7m/s wind speed, 72 RPM, for which the experimental torque (power) is approx. 800Nm (6kW), and the drag is 1150N.
There is a FLUENT study that claims to have done it
http://yrc.utcb.ro/p/YRC_2010_THCE_Razvan_Mahu.pdf
They're pre-stall data matches experiment, but they also use a hybrid mesh. Most other validations in the literature were done using BEM codes and they compare well with experiment.
Thanks.
nomad is offline   Reply With Quote
mrf, nrel phase 6 validation, torque, wind turbine
How to access only one phase in multiphase model by UDF wersoe Fluent UDF and Scheme Programming 1 January 4, 2017 07:11
VOF for single phase? vuccj7 FLUENT 0 April 20, 2011 19:59
two Phase column simulation chemeng OpenFOAM 3 August 18, 2010 12:53
Source Term used in Eulerian Model(Two phase) Padian FLUENT 1 May 19, 2008 03:47
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
