Setting both Pressure and Mass Flow at a HeaderInlet
Old   August 5, 2011, 20:04
Default Setting both Pressure and Mass Flow at a HeaderInlet
MentalVacancy is on a distinguished road
I am trying to model a header with one inlet and five outlets. Essentially, I wish to define a mass flow rate and pressure at the inlet so as to obtain the resulting pressures and flow rates at the five outlet boundaries.
Does anyone have any insights into how to go about doing this? The available boundary condition settings in STAR do not seem to allow me to set the problem up this way.
For example, do I need to combine the five outlet surfaces into one part and use a mass flow inlet boundary to specify total pressure, then use derived parts for the pressure readings?
Thanks in advance.
MentalVacancy is offline   Reply With Quote
Old   August 7, 2011, 16:09
abdul099 is on a distinguished road
It is not possible to define pressure and mass flow at the same boundary. You might use the target mass flow option, but it does only adjust the pressure until the target mass flow is reached.
Further it's not possible to get the pressures at the five outlets (assuming they are different) when you don't have any information about the split ratios (how much of the mass flow exits at which outlet). And it should be easy to understand why: The pressure depends on your inlet pressure and the pressure drop in every flow path of your domain. The pressure drop depends on the mass flow through every flow path. And the mass flow depends on the pressure drop in every flow path and the outlet pressure. So the cat is chasing it's own tail. There are too many variables.
You HAVE to fix at least one variable: Either outlet pressure or outlet mass flow or the split ratios (e.g. 10% at the first outlet, 30% at the second outlet etc.).
abdul099 is offline   Reply With Quote
Old   August 8, 2011, 01:37
Thanks for your input.
I have managed to implement something similar to what I was going for. I combined all five outlets as a single boundary, set this boundary as a mass flow inlet, then set the total outflow I desired. This allowed me to set a pressure outlet as my inlet.
I then created a number of constrained planes to allow me to output the outlet pressures (since the outlets were no longer selectable separately.).
It does give me a solution with varied outlet flows which, when combined, equal my total mass flow. The pressure seems to behave oddly, however. It seems as if the inlet pressure is close to (rho*g*h) lower than what I set it to, something I did not see in other configurations. Might the treatment of hydrostatic pressure have changed?
Old   August 8, 2011, 08:31
Ryne Whitehill
rwryne is on a distinguished road
Thanks in advance.
Set the boundary to a Pressure Outlet (it says outlet, but it can act as an inlet). Then under its options, you can enable a "Target Mass Flow" option.
rwryne is offline   Reply With Quote
boundary conditions, cfd, star
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 05:37
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 12:30
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
