Moment Coefficient of 2D Airfoil
Old   August 9, 2011, 18:57
Post Moment Coefficient of 2D Airfoil
yellowCamel is on a distinguished road
I am currently trying to find how to get the leading edge moment coefficient of a one meter NACA 16-006 and I am not getting the right results. I know that I have set up the physics model correctly because I am getting the correct lift and drag coefficients based on a comparison to wind tunnel data from NTRS. It seems as I have set up the moment coefficient report data correctly and the only things that I can see being the source of my error are the reference radius and the axis origin. I have set the reference radius to 1m and the axis origin to [0,0,0] with the reference coordinate system located at the leading edge. Any insight to this problem would be greatly appreciated.
yellowCamel is offline   Reply With Quote
Old   August 10, 2011, 02:01
husker is on a distinguished road
What are the errors of your Cl and Cd values due to the wind tunnel data? The error of Cl should be around %2-%4. However I suppose that your Cd error is higher.
Pitch moment is generally calculated at x=0.25c. Is your wind tunnel Cm calculated at x=0?
husker is offline   Reply With Quote
Old   August 10, 2011, 08:28
Yes, my Cl is within that range. As for the moment coefficient, I do not have wind tunnel data for that range but I know it is incorrect because it is positive when there is a positive angle of attack when I was taking it about the quarter chord and the values were about .4-.5. I switched to the leading edge because it seemed simpler to set up since the coordinate system was already located there and it is simple to convert to the Cm at the quarter chord.
Old   August 11, 2011, 05:25
Interesting,
As a result I think your Cd error is too high to calculate Cm. It is normal. Cd evaluating is very challenging.
When I need Cm value, I prefer 2D codes like Xfoil.
Old   August 27, 2011, 05:41
abdul099 is on a distinguished road
Drag shouldn't have that much influence on the moment coefficient.
Are you sure, you've defined your axis the right direction? In my testcase, it's behaving exactly as one would expect. The only thing I'm unsure about is the reference radius, but there's only a proportional correlation to Cm, so it will not change a positive to a negative number.
abdul099 is offline   Reply With Quote
airfoil, coefficient, moment, star-ccm+
2D Airfoil Centre of Pressure, Pitch Moment and Pitch Moment Coefficient aerospain ANSYS 2 May 4, 2020 20:47
lift, drag and moment of airfoil dennis0131 Main CFD Forum 10 April 27, 2010 12:12
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 06:56
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 06:51
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
