Issue with MRF discontinuity
Old   November 27, 2023, 12:36
Question Issue with MRF discontinuity
Gilberto S.
Gilsuss is on a distinguished road
Hi there,
I am experiencing some issues concerning discontinuity in the MRF region.
My simulation comprises a Moving Reference Frame region within an air volume region. Beneath this MRF region, there is a solid region with a constant heat source.
I initiate the simulation with a heat source set to zero to initially stabilize the flow. However, upon convergence, a discontinuity arises between the MRF and the air regions (the speed profile from one doesn't match the other).
I am utilizing the models, as shown in the attached image (models for the fluid region).
I've already set the interfaces as mixing-plane interfaces, and the angular velocity is 2600 RPM.
If anyone has insights on this matter, please lend me a hand
Gilsuss is offline   Reply With Quote
Old   February 1, 2024, 12:08
Lightbulb
Gilberto S.
Originally Posted by Gilsuss View Post
Hi there,
So, what I actually found out was that the mixing plane interfaces make an "average" of the MRF effects as a whole, creating a discontinuity between the air domain and the MRF domain.
I hope someone finds this information useful
discontinuity, flow and heat transfer, mrf
OpenFOAM MRF: Rotating - Stationary Zone Interface Discontinuity b16328 OpenFOAM Running, Solving & CFD 0 June 1, 2023 10:33
[snappyHexMesh] cannot find MRF cellZone Ahyar OpenFOAM Meshing & Mesh Conversion 2 November 2, 2021 02:28
[ANSYS Meshing] Ducted propeller MRF issue cagriaydin ANSYS Meshing & Geometry 8 January 28, 2020 09:49
Fan-assisted Natural Ventilation Simulation - Issues with results for an MRF case Tellur OpenFOAM Running, Solving & CFD 0 July 15, 2016 02:04
Particle tracking in and after MRF andreas0209@hotmail.com OpenFOAM Running, Solving & CFD 1 July 6, 2015 08:36
