Repeated table input
Old   September 29, 2011, 07:35
Default Repeated table input
Hamza Motiwala
hamzamotiwala is on a distinguished road
Hello everyone,
I am simulating an Exhaust gas recirculation model and I give in my input in the form of a table. The table is divided into 720 time steps corresponding to each crank angle turned.
I want to repeat this cycle a couple of times. How can I get starccm+ to repeat the cycle everytime it reaches the end of the table.
As a work around I had copy pasted the data one after the other 5 times in the same excel sheet along with increasing the time respectively to run the cycle 5 times .
Is there a way to do it automatically?
thanks,
Hamza
hamzamotiwala is offline   Reply With Quote
Old   October 1, 2011, 18:08
abdul099 is on a distinguished road
It is possible, but I have to check how to do it.
abdul099 is offline   Reply With Quote
Old   October 3, 2011, 05:12
Hamza Motiwala
Thanks! I really appreciate it.
Old   October 5, 2011, 19:08
Okay, the solution for your problem is:
- Read in the table for one cycle as usual. More than one cycle doesn't harm, but is not necessary.
- Create a field function which uses the mod or fmod function (see field function programming reference in the online help) to give back a cyclic time. For example fmod($Time, 0.1) will take the current time and subtract 0.1 seconds until the remainder is less than 0.1. Let' call this $modTime
- Create an interpolation field function. Interpolate the table (or the right column) by $modTime.
- Use the later field function as input for your boundary condition
Hope this helps
Old   October 6, 2011, 02:23
Hamza Motiwala
Hey abdul,
Thanks for the reply.
certain things are unclear to me.
my time-step is .000060611 secs
total physical time is .2181996
these are the field functions i wrote :
modTime = fmod($Time, .000060611)
interpolateTable(@Table("hd_egr"), "Time", SPLINE, "massflow", $modTime)
now if my first time step would be .000060611 secs. I get a remainder 0 and then does the second field function above interpolate for a massflow value for time 0 in the table.
If the remainder remains 0 all the time, how does it move further? I am lost here completely. I think I have not understood this thing correctly.
How do I repeat the table n number of times?
Can you explain further please?
Thanks,
Hamza
Old   October 6, 2011, 18:33
You nearly got it. I think, your total physical time should be the cycle time, shouldn't it? So your first field function should be
modTime = fmod($Time, .2181996)
So every time step your time will progress for 0.00006.... seconds until it finishes the first cycle. Then the cycle time will be cut and your simulation keeps on going, repeating the table from time the beginning.
There is no number which defines how often the table should be repeated. The table will be repeated until your stopping criterias are satisfied and the simulation stops. So make sure your stopping criterias are set appropriate.
Old   October 7, 2011, 17:18
Hamza Motiwala
Thanks a lot abdul!
I have made the necessary corrections and started the simulation. Hope to get some positive results on monday .
Old   October 12, 2011, 02:51
Hamza Motiwala
It worked perfectly. Thanks a lot for the help man!
Old   October 13, 2011, 17:00
You're welcome
Old   December 7, 2011, 04:21
Default exhaut converge
rabat is on a distinguished road
Hi Hamza,
how do setup the physics conditions by Your calculation.
My residuals is not really converge, I got Floiting Point exception after 3 cycles.
Thanks,
Rabat
rabat is offline   Reply With Quote
Old   December 7, 2011, 08:51
Hamza Motiwala
Hey Rabat,
I didnot understand your question. Do you want to know what physics models I used?
I have run my simulations for as long as 14 cycles till now and I have had no problems. My first 2 or sometimes 3 cycles appear to be a little different from one another but later everything is fine.
elaborate a little more and I will try providing more data from my side.
Best Regards,
Hamza
Old   December 8, 2011, 06:52
Hey Hamza,
which turbulant model did You use?
I use at the moment: coupled energy, coupled flow, k-epsilon turbulent and implicit unsteady.
Did You change the solver parameters?
Coupled implicit: courant number ramp or AMG linear solver
How many inner iteration do you use?
I would appreciate if You answer my quetions.
Best Regards,
Rabat
Old   December 9, 2011, 04:35
Hamza Motiwala
I have used K Omega and K epsilon for my simulations.
I have used both coupled and segregated models.
currently I am simulating with Segregated and K Omega models.
In my current simulation I have 40 inner iterations and I am running the simulation for 8 cycles that sums up to a total of around 230000 iterations.
I did play with the courant number but since I am using segregated flow right now, its not relevant here. Apart from that I am using default values.
No matter what the model, I think you should not have any problems running this code. You should be able to run it for as many cycles as possible.
You should try running your simulation with default settings.
What I dont understand is, if you can run the cycle once you should be able to run it a 100 times.
Input Parameter Value into Table zephyrus17 CFX 0 February 9, 2011 22:22
Fluent UDF: Thru external input BS FLUENT 0 March 26, 2008 18:53
input curve BC carno Siemens 2 June 22, 2005 05:03
Transient user input table Bart Siemens 0 January 10, 2005 01:27
TABLE INPUT LORENZO Siemens 0 June 9, 2004 12:04
