January 24, 2012, 09:22 |
Specifying plane to transform to 2D
Mark
I'm attempting to convert a 3D mesh to a 2D mesh. However the program only seems to want to cut the mesh down a plane that is unspecified and a plane I don't want it to be cut down. Is there anyway one can specify the plane to be cut? I've created planes, I've split the regions... thoughts?
January 24, 2012, 09:49 |
Your 2D mesh will be extracted from the xy-plane (z=0) of the laboratory coordinate system. So you have to position your 3D mesh in the way that the xy-plane can be used to extract your 2D mesh. Ensure that only boundaries are at the xy-plane. It is not possible to cut volume cells by the conversion process.
Using a Plane id in Fluent UDF | cdf_user | Fluent UDF and Scheme Programming | 13 | October 17, 2023 00:06 |
Meshing a Mixing Plane using ICEM | Will Anderson | FLUENT | 0 | November 6, 2010 17:08 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
Relief Plots in CFX | Michael | CFX | 15 | June 30, 2006 08:01 |
