January 13, 2020, 05:00 |
Design parameters to adjust the geometry
Nadine Lock
Rep Power: 6 |
Hello everybody,
I have a few questions about design parameters to adjust the geometry:
January 14, 2020, 03:56 |
gago
Rep Power: 6 |
Hello. As far as I know, If you want to create design parameter in STAR CCM+ you should do it in 3D-CAD module and you can not open a surface mesh parts in 3D-CAD. However if you have CAD parts it would work fine to create design parameters via selecting expose parameter command. Regarding the Free Surface Forming again you are able to do it in 3D-CAD module.
January 16, 2020, 01:10 |
Nadine Lock
Rep Power: 6 |
ok thanks.
- How is it possible to change the dimensions of a CAD part (blue) that is opened with 3D CAD? As far as I've tried it, I could e.g. only carry out further extrusions etc., but do not change the existing block. - Is there a way to edit surface mesh parts with free surface forming, e.g. after exporting the surface mesh part, editing with another program and then importing it? |
Importing SOLIDWORKS geometry into ANSYS design modeler. | Pegasos | ANSYS | 1 | March 22, 2017 01:27 |
Infinity Jet Design Parameters | geometrixeng | Main CFD Forum | 1 | January 21, 2015 10:34 |
Real Geometry and input parameters of industrial boiler | Michail | Main CFD Forum | 2 | March 28, 2013 14:34 |
Design Modeler imported geometry | natantyt | ANSYS Meshing & Geometry | 0 | June 11, 2011 19:44 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 08:17 |
