Increasing performance changing AMG parameters in Star-CCM+
Old   March 22, 2012, 07:51
Default Increasing performance changing AMG parameters in Star-CCM+
archeo is on a distinguished road
Hi. I am simulating a rotating machine with heat tranfer and heat conduction. The pressure takes long before converging. Is there any parameter in the AMG solver I could change to increase the performances? (the BicGstab is already on)
archeo is offline   Reply With Quote
Old   March 23, 2012, 09:23
Ryan Coe
ryancoe is on a distinguished road
For the Multi-Grid, I think that you may be able to increase the group size to improve convergence speed.
I would also experiment with changing the under-relaxation factors.
Ryan
ryancoe is offline   Reply With Quote
Old   March 26, 2012, 05:13
I saw some improvment in the convergence behavior when increasing the group size. Thanks for your advice. I changed the group size for the pressure. Do you think I could expect further improvments when changing the group size on the momentum? Does the group size affect the memory requirement?
Old   March 26, 2012, 14:09
Ryan Coe
I'm not sure whether increasing the group will directly affect the memory requirement.
Multigrid methods take advantage of the ability of coarser grids to damp transients more quickly. Without knowing more about your simulation its tough to say how the momentum performance may change. I guess its worth a try, right?
Ryan
Old   March 26, 2012, 18:45
Arjun
arjun will become famous soon enougharjun will become famous soon enough
By pressure do you mean continuity( mass convergence)?
If yes then there are lots of other factors that affect it. The heavy impact comes from skew or non-orthogonality. If possible improve the mesh.
arjun is offline   Reply With Quote
amg, performance, star-ccm+
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
Fluent Vs Star CCM firda Main CFD Forum 3 February 26, 2011 02:51
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
error in star ccm maurizio Siemens 3 October 16, 2007 05:17
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
