Monitor engineering data - Mflux not consistent? |
July 28, 2009, 13:02 |
anonymous
I have a simple model of a duct with variable cross-section area. Along its length, I've defined several shells which represent cross sections. If I load the converged solution and calculate the mass flow rates through Post >> Fluxsum >> Shell type..., I get the same value for all shells, and that's how it should be. However, if I define an internal boundary at these cross sections and let Mflux be monitored, the values I get in the *.erd file make no sense at all (not in kg/s nor in kg/( m2 s) ). I'm pretty sure the internal boundaries are defined correctly - all faces are oriented to the same direction and so on. The Mflux (in [kg/s]) are consistent at the inlet and outlet with the boundary conditions. But the ones within the solution domain are not. Does anyone know what is going wrong? |
flux, mass, mass flux, mflux, monitor mass flux |
Exporting data (cell values, ascii) and obtaining more data than cells! | TfG | FLUENT | 3 | April 3, 2015 00:18 |
【Help】"Error: Update_Time_Level: invalid data" | Chen | FLUENT | 2 | August 24, 2014 07:51 |
export data at nodes | Meenu | FLUENT | 1 | December 30, 2011 01:24 |
Saving particle (DPM) data to file? | Philip | FLUENT | 2 | June 12, 2006 01:41 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
