June 1, 2010, 10:22 |
how to continue a solution, if it is stopped
hang zhu
Rep Power: 15 |
hello,
i was working on a solution which could take very long time. but it was stopped because my device was full. i wish i do not need to do it from the beginning. is it possible to continue the solution from the moment which it was stopped? thx! |
June 1, 2010, 13:42 |
Pauli
Rep Power: 17 |
Yes, you want to perform a restart run.
At the command line enter "help rdata" to see details. |
June 4, 2010, 10:14 |
Purushothama Chippar
Rep Power: 15 |
Yes you can. Go to Navcenter-Analysis Preparation/Running - Analysis (Re) Start..Select standard restart for restart option - apply - write problem file again. Now it will restart from the old iteration. But I think it will not work if u have modified anything in your udf files (if you are using) since the last stop.
June 7, 2010, 02:28 |
#4 | |
Mark Olesen
Rep Power: 40 |
June 8, 2010, 03:21 |
hang zhu
Rep Power: 15 |
thank you all. i will try and see!
June 23, 2010, 04:59 |
hang zhu
Rep Power: 15 |
now i want to make sure, wheather the restart works, wenn i modify sth. and write the geomerty data again.
Regards hang |
continue LES from the time it stopped | holand_us | OpenFOAM Running, Solving & CFD | 1 | April 6, 2010 16:05 |
continue LES simulation after it stopped | holand_us | OpenFOAM Running, Solving & CFD | 1 | March 29, 2010 03:50 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
EULER-Forward-Method | freak | Main CFD Forum | 4 | June 12, 2001 09:19 |
