March 6, 2015, 12:00 |
ANSYS mechanical:contact issue
Liang Chen
Rep Power: 11 |
Hi
A lot of information but I think it is straightforward. Thank you in advance! Some background information: I am modeling an aircraft wing. And I have surface body represents the wing skin and solid bodies for ribs. In the CAD model, the surface body is lofted based on the ribs profile, so the surface should be right on top of the rib. So in the ANSYS Mechanical, I set a thickness of 2mm for the surface(skin) and the offset is bottom. For contacts, it is set to Bonded. Here are the questions: The first one is how to identify the top & bottom of a surface? The second one is: there are two penetration or gap values in contact tool(geomtric penetration and penetration), so which one is referred to when the warning message says the initial penetration/gap is large? Below is one row of the initial information from contact tool. And the color of this row is orange and also I received a warning about large initial penetration/gap. So could anyone explain to me how these values listed are calculated? And do the surface thickness and offset type I mentioned in the background information play any role in here? Name: bonded-r_middle To skin Contact Side: Contact Type: Bonded Status: Closed Number of Contacting: 1308 Penetration(mm): 1.588e-012 Gap(mm):0 Geometric Penetration(mm): 1.2928 Geometric Gap (mm): 0.23277 Resulting Pinball (mm): 1.9525 Real Constant: 17 |
Strange issue while launching ANSYS workbench in CentOS 6.4 | Philip_C | ANSYS | 11 | August 29, 2013 06:44 |
Ansys Workbench Issue | umer100 | ANSYS | 0 | May 16, 2013 08:38 |
[ANSYS Meshing] Issue with modeling dynamic capillary rise in a capillary tube | cp703 | ANSYS Meshing & Geometry | 13 | March 22, 2013 20:11 |
ANSYS LS-DYNA export, | mechanicaldesign | ANSYS | 0 | July 22, 2012 03:30 |
ANSYS 13 Multifield, | mechanicaldesign | CFX | 2 | May 26, 2012 09:32 |
