Home > Forums > Software User Forums > SU2 > SU2 Installation
Serial install problems
Old   February 16, 2014, 16:32
Default Serial install problems
leo_NM is on a distinguished road
Good afternoon guys
I'm new to SU2 and as a good start point I decided to install it rsrs.
I followed the instructions in the official page but I'm having some trouble to make it work.
First: When I installed the 64 bit serial version for Win, it didn't created any Stanford directory, just a "SU2" one.
Second: I'm trying to configure the variables but I don't know if this is the right way( see the picture) .
third: After installing and re-intalling SU2 a bunch of times the same problems still there. rsr
what should I do ?
thanks in advance
leo_NM is offline   Reply With Quote
Old   February 18, 2014, 09:12
Yibin Dou
adam_annie is on a distinguished road
hi
I have installed the su2 v3.0 win32 in windows 7 os. For su2 v3.0, it only have 'SU2' directory after installation.and you are right in setting enviorement variable 'su2_run'.
Originally Posted by leo_NM View Post
Good afternoon guys
what should I do ?
thanks in advance
adam_annie is offline   Reply With Quote
Old   February 18, 2014, 20:38
I solved the "problem".
In fact it just the SU2 directory appeared after the installation.
Before the run, just copy the mesh and setup files inside the installation directory (SU2).
When you run the setup file by the prompt, everything works together.
thank you guys.
[swak4Foam] Install swak4Foam on OpenFOAM1.7.1 on Ubuntu 13.04 kobayashi OpenFOAM Community Contributions 2 January 5, 2014 17:33
Environment errors with .deb install and ubuntu 13.04 64 bit jonathanbyrn OpenFOAM Installation 14 September 26, 2013 05:22
Installation problems ianz8802 OpenFOAM Installation 37 January 30, 2009 13:20
Installation problems about Paraview and PV3foamreader clark_liang OpenFOAM Installation 1 January 12, 2009 06:05
Having problems to Install OpenFOAM 13 release of PowerLab2 ed_teller OpenFOAM Installation 0 June 11, 2007 10:50
