Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Drag under Euler formulation
Like Tree1Likes
  • 1 Post By fpalacios
Old   July 23, 2013, 09:42
Default Drag under Euler formulation
MENDES BORTOLAZZI Andre
Bortolazzi is on a distinguished road
Hi developers,
I would like to ask you how the drag of a profile is computed using Euler analysis. In another post, I've been told the total drag was computed by integrating over the surface, but how is the shear stress tension localy computed?
Are the concepts of displacement thickness and momentum thickness employed?
Thanks in advance,
Andre
Bortolazzi is offline   Reply With Quote
Old   August 19, 2013, 12:32
Francisco Palacios
fpalacios is on a distinguished road
Hi Andre,
To compute the Drag (inviscid and viscous) we perform a direct integration of the forces on the surface. More details in http://su2.stanford.edu/documents/SU2_AIAA_ASM2013.pdf
And the subroutines in the code:
void CEulerSolver::Inviscid_Forces(CGeometry *geometry, CConfig *config)
void CNSSolver::Viscous_Forces(CGeometry *geometry, CConfig *config)
Best,
Francisco
Originally Posted by Bortolazzi View Post
Hi developers,
Thanks in advance,
Andre
beatlejuice likes this.
fpalacios is offline   Reply With Quote
Old   August 20, 2013, 08:14
Hi Francisco,
Thanks for your reply. In the end, I guess I was just strugling with spurious drag, because SU2 provided some small values for drag coefficient when running a bidimensional Euler analysis in low Mach flow (thus, no drag). I was confused, because the spurious drag was increasing with the angle of attack, but after some research, I found out this is the normal behaviour for numerical drag.
Thanks again for your attention.
Best regards,
Andre
Drag law customization (Euler) Aris FLUENT 0 December 1, 2006 09:39
Dimensionless formulation of Euler equations jvn Main CFD Forum 3 July 8, 2004 13:29
Drag formulation REMY FLUENT 0 March 10, 2002 14:05
Drag formulation remy Main CFD Forum 0 March 10, 2002 13:05
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
