Home > Forums > Software User Forums > SU2
Custom Source Terms
Old   January 30, 2013, 10:39
Default Custom Source Terms
sss3700 is on a distinguished road
I'm also interested in adding some custom source terms. Could you please explain the best approach to do that?
sss3700 is offline   Reply With Quote
Old   January 30, 2013, 10:51
Amrita Lonkar
Amrita Lonkar is on a distinguished road
The best place to add new source terms to the flow equations is in the method called "Source_Template" in the file solution_direct_mean.cpp.
This method is directly connected to the rest of the code, which makes it easy to implement new source terms. You will have to specify the following option in the configuration file to activate it. SOUR_NUM_METHOD_FLOW= PIECEWISE_CONSTANT
I would also recommend that you download the new version of SU2 that will be available towards the mid of February for this particular problem, it will include some important changes to ease the implementation of new source terms.
Thanks again for your questions! Let me know if you need more assistance, we are very happy to help potential developers!
Amrita Lonkar is offline   Reply With Quote
Old   January 31, 2013, 00:34
Sean R. Copeland
copeland is on a distinguished road
Just a follow up on Amrita's comments:
The inviscid fluxes, viscous fluxes, and source terms are all handled independently of one another and you can see the structure by taking a look at CIntegration::Space_Integration in the integration_structure.cpp source code file. A selection of PIECEWISE_CONSTANT integration of the source terms allows for rapid implementation of new source terms in the CSource_Template class located in the numerics_source.cpp file.
There are plenty of examples of specialized source terms in numerics_source.cpp that you can reference as you input your own custom source terms.
Regards,
Sean
copeland is offline   Reply With Quote
Old   February 17, 2013, 23:05
I need to use the x-y-z data for the current node in the calculation of my custom source terms. I'm trying to use the 'Coord_0' variable that I set with 'SetCoord' in 'solution_direct_mean.cpp'.
However, I get a segmentation fault when I try to use the 'Coord' variables in 'numerics_source.cpp'.
Excerpt from 'numerics_source.cpp':
void CSource_Template::SetResidual(double *val_residual, double **val_Jacobian_i, CConfig *config) {
double P,rho_u,rho_v,rho_w, xx, yy,zz,Beta_Sq,Core,L,K,A0,A1,A2,A3,
mx,my,mz, Ax,Ay,Az,dmx_dx,dmy_dy,dmz_dz,dAx_dx,dAy_dy,dAz_dz,dBx_dx,dBy_dy,dBz_dz,
dCx_dx,dCy_dy,dCz_dz,d2Ax_dxx,d2Ay_dyy,d2Az_dzz,dCore_dx,dCore_dy,dCore_dz,
dCore_dxx,dCore_dyy,dCore_dzz,dP_dx,dP_dy,dP_dz,drho_u_dx,drho_u_dy,drho_u_dz,
drho_v_dx,drho_v_dy,drho_v_dz,drho_w_dx,drho_w_dy,drho_w_dz,drho_u_dxx,drho_u_dyy,
drho_u_dzz,drho_v_dxx,drho_v_dyy,drho_v_dzz,drho_w_dxx,drho_w_dyy,drho_w_dzz, rho,
Beta_Squared, S1,S2,S3,S4,mu_tot;
cout << "Get Coordinates " <<endl;
xx = Coord_0[0];
yy = Coord_0[1];
zz = Coord_0[2];
cout << "Coordinates set" << endl;
Old   February 20, 2013, 01:42
Thomas D. Economon
economon is on a distinguished road
Sounds like you are on the right track... An example might be setting the following in solution_direct_mean.cpp:
/*--- Set coordinates ---*/
solver->SetCoord(geometry->node[iPoint]->GetCoord(),geometry->node[iPoint]->GetCoord());
and then these coordinates may be accessed in the source routine of the numerics class under the variable Coord_i, i.e. Coord_i[0], Coord_i[1], & Coord_i[2].
Hope this helps!
economon is offline   Reply With Quote
Old   February 28, 2013, 22:04
I've added the following code in the CEulerSolution::Source_Residual method:
	if (MMS) {
	   /*--- loop over points ---*/
	   for (iPoint = 0; iPoint < geometry->GetnPointDomain(); iPoint++) {
	      if ( !geometry->node[iPoint]->GetBoundary() ) {
	         /*--- Set solution  ---*/
	         solver->SetConservative(node[iPoint]->GetSolution(), node[iPoint]->GetSolution());
	         /*--- Set incompressible density  ---*/
	         solver->SetDensityInc(node[iPoint]->GetDensityInc(), node[iPoint]->GetDensityInc());
	         /*--- Set beta squared  ---*/
	         solver->SetBetaInc2(node[iPoint]->GetBetaInc2(), node[iPoint]->GetBetaInc2());
	         /*--- Set control volume ---*/
	         solver->SetVolume(geometry->node[iPoint]->GetVolume());
	         /*--- Set coordinates for MMS ---*/
	         /*--- Compute Source term Residual ---*/
	         solver->SetResidual(Residual, Jacobian_i, config); //MMS Modification
	         /*--- Set Source Residual ---*/
	         //node[iPoint]->SetRes_Sour(Residual);
	         node[iPoint]->AddRes_Conv(Residual);
	       } //added IF for MMS Modification
Is this the correct approach for adding a constant source term?
Old   March 18, 2013, 15:46
I'm also wondering if the source terms should be non-dimensionalized. If so how are the solution variables non-dimensionalized in the solver code?
Old   March 23, 2013, 23:04
Francisco Palacios
fpalacios is on a distinguished road
The non-dimensionalization of the code is described in
http://su2.stanford.edu/documents/SU2_AIAA_ASM2013.pdf
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   March 24, 2013, 20:02
I've been using that document, but it mentions an "internal document" by Prof. Feng Liu: "Non-dimensionalization of the Navier-Stokes Equations" that might be the missing piece that I need.
I'm trying to write custom source terms so that I can conduct a verification of the order of accuracy of the code using the Method of Manufactured Solutions (MMS). So far it's not working, and I think it's due to the non-dimensionalization of the source terms (or there's a problem with this part of the code).
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 05:18
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
