March 27, 2013, 16:00 |
What type of problem is this
Ron Burnett
Rep Power: 13 |
Have successfully worked thru most of the tutorials and a few of my own examples. However, I don't know what to make of this:
------------------------------ Begin solver ----------------------------- Iter Time(s) Res[Rho] Res[nu] CLift(Total) CDrag(Total) 10 1.941727 -1.#IND00 -1.#IND00 1.#QNAN0 -1.#IND00 20 1.937476 -1.#IND00 -1.#IND00 1.#QNAN0 -1.#IND00 30 1.934968 -1.#IND00 -1.#IND00 1.#QNAN0 -1.#IND00 40 1.933293 -1.#IND00 -1.#IND00 1.#QNAN0 -1.#IND00 50 1.932275 -1.#IND00 -1.#IND00 1.#QNAN0 -1.#IND00 60 1.931590 -1.#IND00 -1.#IND00 1.#QNAN0 -1.#IND00 70 1.931113 -1.#IND00 -1.#IND00 1.#QNAN0 -1.#IND00 80 1.930741 -1.#IND00 -1.#IND00 1.#QNAN0 -1.#IND00 90 1.930451 -1.#IND00 -1.#IND00 1.#QNAN0 -1.#IND00 100 1.930218 -1.#IND00 -1.#IND00 1.#QNAN0 -1.#IND00 110 1.929892 -1.#IND00 -1.#IND00 1.#QNAN0 -1.#IND00 120 1.929744 -1.#IND00 -1.#IND00 1.#QNAN0 -1.#IND00 I can post more related info if necessary. |
March 28, 2013, 03:48 |
It seems that your simulation is not converging any more. It would be nice to see the residual plot or flowfield plot or cp/cf plot to observe what's going on in your simulation.
March 28, 2013, 08:55 |
Ron Burnett
Rep Power: 13 |
The output files have similar content, ......nothing meaningful.
April 11, 2013, 13:29 |
Rep Power: 14 |
Hello Ron,
Can you please post your config file as well as information about your installation? |
April 11, 2013, 16:19 |
Ron Burnett
Rep Power: 13 |
The version being used is Win (32bit) serial. I get similar behavior on another machine running Win (64bit) parallel. The model, Simple3, is a .177cal round nosed cylinder......hence the low Rn. Code Saturne works OK with it.
Hope this helps. |
April 12, 2013, 13:45 |
Michael Colonno
Rep Power: 13 |
The solution is diverging; it's not a platform-specific issue. We'll have to review the input parameters and mesh to track down the issue.
April 16, 2013, 12:15 |
Ron Burnett
Rep Power: 13 |
Here is the mesh file. Geometry and surfaces generated with Code-Saturne (Netgen based), volume from enGrid, exported in SU2. Hopefully you can figure this out.
https://www.box.com/s/h864wutc8dj954hnrlx3 |
April 16, 2013, 14:10 |
Hi rnburne,
well i tested it with minor modification in your SU2 config file, it runs without any problem. See the attached snapshot and the modified SU2 config file. |
April 16, 2013, 17:08 |
#9 |
Ron Burnett
Rep Power: 13 |
Thanks for the help, though I'm not at all sure why those changes worked.
When incorporated into the files I'm using the solver now returns negative pressures throughout. Any thoughts on that? Last edited by rnburne; April 17, 2013 at 12:25. |
April 18, 2013, 13:11 |
#10 | |
Francisco Palacios
Rep Power: 15 |
Today we are releasing SU2 2.0.3 where we have fixed some platform related issues. Could you please run again your simulation using the new code? Best, Francisco |
buoyantSimpleFoam for HVAC application | Mojtaba.a | OpenFOAM Running, Solving & CFD | 7 | November 16, 2017 15:49 |
Inlet patch problems | martyn88 | OpenFOAM Running, Solving & CFD | 6 | April 21, 2017 18:34 |
multiphaseInterFoam: timestep error by simulating a co-extrusion nozzle | Quatschinsky | OpenFOAM Running, Solving & CFD | 7 | March 27, 2014 05:08 |
Instable natural convection case | Peter88 | OpenFOAM | 5 | August 18, 2011 01:23 |
Problems with Turbulence Modeling | ezsoal | OpenFOAM Running, Solving & CFD | 4 | November 26, 2009 15:12 |
