v2.0.8 seg fault occurs after convergence is achieved |
October 18, 2013, 17:46 |
Hi, everyone,
I am new to SU2. I tried to run some sample cases. However, I always got a seg fault when convergence was achieved. After some investigations, I found out that the seg fault occurs in the function call MergeCoordinates in output_structure.cpp: Line 4863. Interestingly, if I put any print out statement right after line 4863, the seg fault no longer occurs. I know there must be something wrong. I do not see any other users experience this issue. I am wondering if this is because I did not install the program correctly or any of my environment settings is not correct. Moreover, I left the dummy print out statement there (in line 4864) and let the program run anyway. I compared my results for the naca0012 sample case with those on SU2 website (http://adl.stanford.edu/docs/display...Start+Tutorial). In my flow.dat file, it looks like: TITLE = "Visualization of the volumetric solution" VARIABLES = "x","y","Conservative_1","Conservative_2","Conserv ative_3","Conservative_4","Pressure","Pressure_Coe fficient","Mach", "Sharp_Edge_Dist" However, in flow.plt file on SU2 website, it looks like: TITLE = "Visualization of the volumetric grid" VARIABLES = "x", "y", "z", "Density", "Velocity_x", "Velocity_y", "Velocity_z", "Pressure", "Mach_Number" Apparently, they are generated by different functions. Again, is it normal? or if I need to change anything in my cfg file or environment settings? Last thing is in my flow.dat, most numbers look fine except there are some "nan" for Pressure_Coefficient. I am very sorry. I listed a lot of issues. They may be caused by the same problem. I am really frustrated. Please help!! Any advices, suggestions, and/or comments will be appreciated! Thank you in advance! |
October 19, 2013, 02:14 |
Try reinstalling fresh copy of SU2 2.0.8 and also refer to the following thread: http://www.cfd-online.com/Forums/su2...seg-fault.html |
October 21, 2013, 17:01 |
#3 | |
Thanks for the reply. I did try to clean and rebuild the program. I used "make clean" and "make uninstall". It did not solve the problem.
Did I use the correct way to remove an old version program? Quote:
November 5, 2013, 16:46 |
Thomas D. Economon
Rep Power: 14 |
Were you able to resolve the issue by downloading and installing a fresh version of the code (2.0.8) as described in the post that was linked? T |
November 27, 2013, 06:21 |
wangjian
Rep Power: 12 |
hello, I also I also encountered the problem about seg fault. Do you solve the problem? And could you tell me the way?
Thank you very much. |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
interDyMFoam in OF 2.0.1 : seg fault during mesh refinement | michaelb | OpenFOAM Running, Solving & CFD | 3 | July 2, 2012 08:16 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Workbench 11-Linux Intel EM64T platforms Seg fault | Maciej Karczewski | CFX | 5 | April 19, 2010 03:37 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
