Running CFD parallel. There is no geometry file! |
April 9, 2014, 07:35 |
Running CFD parallel. DDC isn't working.
Carlos Alexandre Tomigawa Aguni
Rep Power: 12 |
Hello guys! I tried to run Onera M6 in parallel using parallel_computing.py and got an error reporting that There is no geometry file (GetnZone))!
What might that be? Code:
the command: mpirun -np 8 -machinefile hosts /scratch/ramos/su2mpi/bin/SU2_CFD config_CFD.cfg the location: /scratch/ramos/su2tests/oneram6v1 cstr=mesh_ONERAM6_inv_1.su2 There is no geometry file (GetnZone))! cstr=mesh_ONERAM6_inv_1.su2 There is no geometry file (GetnZone))! cstr=mesh_ONERAM6_inv_1.su2 There is no geometry file (GetnZone))! cstr=mesh_ONERAM6_inv_1.su2 There is no geometry file (GetnZone))! cstr=mesh_ONERAM6_inv_1.su2 There is no geometry file (GetnZone))! cstr=mesh_ONERAM6_inv_1.su2 There is no geometry file (GetnZone))! cstr=mesh_ONERAM6_inv_1.su2 There is no geometry file (GetnZone))! cstr=mesh_ONERAM6_inv_1.su2 There is no geometry file (GetnZone))! Wed Apr 9 08:04:56 BRT 2014 Code:
config_CFD.cfg errput errput2 hosts inv_ONERAM6.cfg inv_ONERAM6_JST.cfg jobp2.sh mesh_ONERAM6_inv.su2 openmpi_exemplo_job_PBS.sh Last edited by CrashLaker; April 9, 2014 at 19:57. Reason: Found out a more general subject. |
April 9, 2014, 16:44 |
Heather Kline
Rep Power: 13 |
This error indicates that the program was not able to find the mesh file. From the error message, it is looking for "mesh_ONERAM6_inv_1.su2", so most likely that mesh file does not exist in the working directory.
Based on your scratch file, it looks like what might be happening is that the mesh is never decomposed. The parallel computation looks for the mesh file name with an "_n" at the end because it expects that the mesh has already been split. This is executed automatically if you use the parallel_computation.py script, and you can also use SU2_DDC manually if you would prefer. Since it looks like neither of these are being executed, the mesh is not divided. I suggest using parallel_computation.py. For more details, please see http://adl-public.stanford.edu/docs/...ED/Running+SU2 |
April 9, 2014, 16:53 |
#3 | |
Rep Power: 12 |
I realized that DDC wasn't creating new meshes. After correcting some other minor mistakes now I'm facing a new error in which DDC is sending all the original mesh points to the first Domain only. Code:
---------------------- Read grid file information ----------------------- Three dimensional problem. 582752 interior elements. 582752 tetrahedra. 108396 points, and 0 ghost points. ------------------------ Divide the numerical grid ---------------------- Domain 1: 108396 points (0 ghost points). Comm buff: 21.98MB of 50.00MB. Domain 2: 0 points (0 ghost points). Comm buff: 0.00MB of 50.00MB. Code:
Command = mpirun -np 4 -machinefile hosts /scratch/ramos/su2mpi/bin/SU2_DDC config_DDC.cfg SU2 process returned error '139' [puma52:28738] *** Process received signal *** [puma52:28738] Signal: Segmentation fault (11) [puma52:28738] Signal code: Address not mapped (1) [puma52:28738] Failing at address: 0x1f231f00 [puma52:28738] [ 0] /lib64/libpthread.so.0 [0x307be0e7c0] [puma52:28738] [ 1] /scratch/ramos/su2mpi/bin/SU2_DDC(_ZN15CDomainGeometryC1EP9CGeometryP7CConfig+0xb35) [0x50df95] [puma52:28738] [ 2] /scratch/ramos/su2mpi/bin/SU2_DDC(main+0x2d4) [0x44ce14] [puma52:28738] [ 3] /lib64/libc.so.6(__libc_start_main+0xf4) [0x307b21d994] [puma52:28738] [ 4] /scratch/ramos/su2mpi/bin/SU2_DDC(_ZNSt8ios_base4InitD1Ev+0x39) [0x44ca89] [puma52:28738] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 1 with PID 28738 on node puma52 exited on signal 11 (Segmentation fault). -------------------------------------------------------------------------- Thanks! |
April 9, 2014, 17:02 |
Heather Kline
Rep Power: 13 |
I'm not certain (maybe someone else on the forum can jump in if they recognize this error), but what I would suggest as a first step is to double check that the code was correctly configured for parallel.
For more details on configuring with parallel tools: http://adl-public.stanford.edu/docs/...on+from+Source |
April 9, 2014, 19:54 |
#5 | |
Rep Power: 12 |
Well.. After some googling I think that error 139 is C's default code for segmentation fault. Another thing is that DDC is sending all the grid's points to the first Domain (1st mpi rank). Leaving nothing to the others as you can see on this log. Code:
Domain 1: 108396 points (0 ghost points). Comm buff: 21.98MB of 50.00MB. Domain 2: 0 points (0 ghost points). Comm buff: 0.00MB of 50.00MB. Can you help me? |
April 9, 2014, 21:16 |
Sean R. Copeland
Rep Power: 13 |
Hi CrashLaker,
I believe Heather's correct, the error is clearly in the partitioning of the mesh and I would suspect it has something to do with the configuration of SU2 and/or it's link to Metis. Please be absolutely sure you've run the SU2 configure script with a link to your MPI compiler and by enabling Metis. Also, please be sure to 'make clean' to ensure that there are no old binaries hanging around with configuration settings that are out-of-date. -Sean |
April 10, 2014, 03:08 |
#7 | |
Rep Power: 12 |
Isn't there anything else I should try? I already compiled it lots of times. |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
patch error OF v2.2.2 mac | hewei | OpenFOAM Installation | 4 | November 30, 2013 16:55 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
