Home > Forums > Software User Forums > SU2
SU2 MPI Error 133
Old   April 8, 2014, 04:52
Default SU2 MPI Error 133 [Solved]
Carlos Alexandre Tomigawa Aguni
CrashLaker is on a distinguished road
Hello guys.
I tried running Onera M6 (Tutorial 2) on a cluster and got an error n#133
which was:
mpirun was unable to launch the specified application as it could not find an executable:
This is what it echoed:
export SU2_RUN="/scratch/ramos/su2mpi/bin"
export PYTHONPATH="${PYTHONPATH}:/scratch/ramos/su2mpi/bin/SU2/run"
time /scratch/ramos/python2.7/bin/python  /scratch/ramos/su2mpi/bin/parallel_computation.py -f inv_ONERAM6.cfg -p 8 -d 8
Traceback (most recent call last):
  File "/scratch/ramos/su2mpi/bin/parallel_computation.py", line 113, in <module>
    main()
  File "/scratch/ramos/su2mpi/bin/parallel_computation.py", line 58, in main
    options.divide_grid  )
  File "/scratch/ramos/su2mpi/bin/parallel_computation.py", line 90, in parallel_computation
    info = SU2.run.CFD(config)
  File "/scratch/ramos/su2mpi/bin/SU2/run/interface.py", line 93, in CFD
    run_command( the_Command )
  File "/scratch/ramos/su2mpi/bin/SU2/run/interface.py", line 279, in run_command
    raise Exception , message
Exception: Path = /scratch/ramos/su2tests/oneram6v1/,
Command = mpirun -np 8 - machinefile hosts /scratch/ramos/su2mpi/bin/SU2_CFD config_CFD.cfg
SU2 process returned error '133'
Executable: -
Node: puma47
while attempting to start process rank 0.
Do you know what might be the cause?
thanks!
Edit: Problem solved!
CrashLaker is offline   Reply With Quote
Old   April 8, 2014, 13:49
Edit. post on wrong thread..
Old   April 8, 2014, 17:12
aniketaranake is on a distinguished road
Hello Carlos,
In your run command it looks as though you've included a machinefile. This is not the default behavior of this script; have you modified it?
Anyway, the problem is that there is a space between the - and the machine file. The corrected command is:
mpirun -np 8 -machinefile hosts /scratch/ramos/su2mpi/bin/SU2_CFD config_CFD.cfg
You can run this command directly (in the directory containing the file hosts) or repair the python script.
Cheers!
Aniket
aniketaranake is offline   Reply With Quote
Old   April 8, 2014, 17:47
Luis Manrique
lmanrique is on a distinguished road
delete this reply!
lmanrique is offline   Reply With Quote
Old   April 9, 2014, 06:52
Originally Posted by aniketaranake View Post
Hello Carlos,
Cheers!
Aniket
Hello Aniket!
Thanks for your reply!
There's indeed a space between "-" and machinefile. But when I go to the file where I've edited it appears correct:
mpi_Command = 'mpirun -np %i -machinefile hosts %s'
But the report print is wrong wth
Old   April 9, 2014, 07:30
Hello. I don't what exactly happened but I rewrote the same line and it worked like a glove.
Thanks Aniket!
Problem solved!
Edit1: Actually a mate seeing this edited the file for me haha. Thanks guys!
mpirun, best parameters pablodecastillo Hardware 18 November 10, 2016 12:36
SU2 compilation with MPI option vinz SU2 Installation 5 March 7, 2013 03:02
Welcome to the Stanford University Unstructured (SU2) forum! economon SU2 0 January 7, 2013 02:48
Error using LaunderGibsonRSTM on SGI ALTIX 4700 jaswi OpenFOAM 2 April 29, 2008 10:54
Is Testsuite on the way or not lakeat OpenFOAM Installation 6 April 28, 2008 11:12
