Home > Forums > Software User Forums > SU2
Terminating SU2 gracefully?
Old   May 16, 2014, 14:43
Question Terminating SU2 gracefully?
Nitin
neetin is on a distinguished road
Is there a way to terminate SU2 and have the solution/visualization files written for the iteration number when process is terminated? This would be useful when convergence criteria is not satisfied but convergence history implies that solution has converged to a certain extent.
neetin is offline   Reply With Quote
Old   June 5, 2014, 02:38
hlk
Heather Kline
hlk is on a distinguished road
Thank you for your question.
If you know where you want the solution to stop ahead of time, you can change the maximum number of iterations.
If you want to stop the solution interactively, you can set the restart frequency to a convenient number of iterations, stop the simulation when desried (ungracefully), and then restart the solution with a small number of iterations. In order to restart, set RESTART_SOL = YES, and change the output restart_flow.dat file to solution_flow.dat (or the SOLUTION_FLOW_FILENAME setting to restart_flow.dat). Note that this will overwrite your history and restart_flow files.
hlk is offline   Reply With Quote
Old   June 5, 2014, 08:47
Nitin
Thank you, Heather.
Pointwise-SU2 joint webinar (April 29th) and SU2 v3.1.0 new release fpalacios SU2 News & Announcements 1 April 30, 2014 02:40
Official release of SU2 V3.0 and SU2 Educational V1.0 fpalacios SU2 News & Announcements 2 January 22, 2014 05:28
SU2 suite has moved to GitHub! fpalacios SU2 News & Announcements 0 August 12, 2013 02:07
Welcome to the Stanford University Unstructured (SU2) forum! economon SU2 0 January 7, 2013 02:48
New SU2 Forum Opened at CFD Online pete Site News & Announcements 0 January 5, 2013 17:59
