June 7, 2014, 01:24 |
How to ascertain convergence
Hedley
Rep Power: 12 |
In laymans terms how would one check if solution is converging or has solved . Any practical example eg look at xxxx column in the history file and if it started at 11.2 in value it should reduce to yy in 5000 iterations .
Stating residuals should be 6 orders of magnitude less just confuses me . |
June 10, 2014, 12:45 |
Heather Kline
Rep Power: 13 |
Thank you for your question.
The residuals are printed as the log of their value. This means that for a 6 order of magnitude decrease the number printed should decrease by 6. In your example, a six order of magnitude convergence would be indicated by 11.2 - 6 = 5.2. The number of iteration it takes to converge will depend heavily on the problem, the mesh, and the CFD settings chosen. Tools like multigrid and the CFL number can accelerate convergence. |
June 10, 2014, 12:51 |
Hedley
Rep Power: 12 |
Thank you for this - I have been watching the output and 5000 iterations on my PC take approximately 3 hours and the residuals hardly move - This is on the sample wing SU2_CFD turb_RAM6.cfg
has anyone run this on a PC so I know what to expect |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
Problems with convergence with an easy system | franzdrs | Main CFD Forum | 0 | June 15, 2009 18:17 |
Defect correction and convergence | ganesh | Main CFD Forum | 4 | June 30, 2006 14:20 |
