Home > Forums > Software User Forums > SU2
parallel computation with PBS error
Like Tree1Likes
  • 1 Post By liujmljm
Old   July 3, 2014, 09:51
Default parallel computation with PBS error
Tansu
tsevine is on a distinguished road
Hello everyone,
i am new with SU2 and trying to do tutorials. But i can't do the parallel computation with PBS.
i got an error when i wanted to submit PBS file using qsub command.Interior of the PBS file is as follows:
#!/bin/bash
# Specify time limit of your job. (HH:MM:SS)
#PBS -l walltime=02:00:00
# Specify the number of CPU cores/parallel processes you need
#PBS -l procs=4
# mail alert at the (e)nd of execution
#PBS -m e
#PBS -M mail@ae.metu.edu.tr
# Give your job a name so it can be found readily with qstat.
#PBS -N name
# standard error output merge to the standard output file.
#PBS -j oe
# Specify the file name for the standard output/error
#PBS -o output
#PBS -e error
# Enter your work directory under /cfd
cd working_directory
# Execute your parallel program
/opt/SU2/bin/parallel_computation.py -f inv_ONERAM6_JST.cfg -n 4
And the error is:
Traceback (most recent call last):
File "/opt/SU2/bin/parallel_computation.py", line 26, in <module>
import SU2
File "/opt/SU2/bin/SU2/__init__.py", line 3, in <module>
from . import run
File "/opt/SU2/bin/SU2/run/__init__.py", line 3, in <module>
from interface import \
File "/opt/SU2/bin/SU2/run/interface.py", line 28, in <module>
from ..io import Config
File "/opt/SU2/bin/SU2/io/__init__.py", line 3, in <module>
from tools import *
File "/opt/SU2/bin/SU2/io/tools.py", line 30, in <module>
from SU2.util import ordered_bunch
File "/opt/SU2/bin/SU2/util/__init__.py", line 5, in <module>
from lhc_unif import lhc_unif
File "/opt/SU2/bin/SU2/util/lhc_unif.py", line 1, in <module>
import numpy as np
ImportError: No module named numpy
On the other hand when i run the python script on command line as follows:
it works and creates all of results correctly.
i added paths SU2_RUN and SU2_HOME to my .bashrc
i don't know how to apply the python script (parallel_computation.py) in PBS.
Any help will be greatly appreciated.
Thanks in advance
Tansu
tsevine is offline   Reply With Quote
Old   July 3, 2014, 10:24
Jianming Liu
liujmljm is on a distinguished road
Originally Posted by tsevine View Post
Hello everyone,
And the error is:
Thanks in advance
Tansu
You should install some soft to make python run in parallel computation. In my case, I don't use parallel_computation script to run. I use following script as the PBS task
#PBS -l nodes=1: ppn=8
#Request hours of walltime
#PBS -l walltime=360:00:00
#PBS -j oe
#PBS -o BXdW.log
#PBS -N BXdW
cd /home/vela/jamesliu/DW
echo " "
echo " "
echo "Job started at `date`"
/opt/sgi/mpt/mpt-2.07/bin/mpirun -np 8 SU2_PRT turb_DW1.cfg
/opt/sgi/mpt/mpt-2.07/bin/mpirun -np 8 SU2_CFD turb_DW1.cfg
/opt/sgi/mpt/mpt-2.07/bin/mpirun -np 8 SU2_SOL turb_DW1.cfg
echo " "
echo "Job Ended at `date`"
echo " "
liujmljm is offline   Reply With Quote
Old   July 3, 2014, 11:59
Tansu
thank you very much Liu
it seems it worked
Old   July 3, 2014, 16:59
Smile
Jianming Liu
it seems it worked
If you want to SU2_SOL to post-process the solution, you should make sure the name of Restart flow input file is same with the name of Output file restart flow. You can try several times, then you can understand.
tsevine likes this.
Old   July 4, 2014, 06:21
Tansu
Thank you again. it is working
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
