Home > Forums > Software User Forums > SU2
Nondimensionalising and Reynolds number
Old   May 23, 2014, 13:28
Default Nondimensionalising and Reynolds number
nilesh
nilesh is on a distinguished road
I am using incompressible flow solver (ROE MUSCL) to solve flow over NACA 0018.
In the physical problem:
density=1.2256, dynamic viscosity=1.789*10^-5, velocity=7.8 m/s, chord=0.2 m.
So the Reynolds number based on chord turns out to be approx 10^5.
In computation:
but I have a mesh with chod=1.
I tried setting MESH_SCALE_CHANGE=0.2 but the Reynolds number is being considered as 5*10^5 as if the chord is still being considered as 1. What is it that is going wrong?
Thanks.
nilesh is offline   Reply With Quote
Old   June 5, 2014, 02:49
hlk
Heather Kline
hlk is on a distinguished road
Thank you for your question.
You need to set the REYNOLDS_LENGTH. By default it is 1.0
I am not familiar with the scale setting you mention - we used to have a convert_to_meter setting, however I think that been discontinued in favor of requiring meshes to be defined in meters. However that will not affect the Reynolds length - it will always be 1.0 unless set otherwise.
hlk is offline   Reply With Quote
Old   June 5, 2014, 14:50
Thomas D. Economon
economon is on a distinguished road
Originally Posted by nilesh View Post
In computation:
Thanks.
For the incompressible solver in SU2, we assume that the Reynolds length is always 1.0 m. In order to define your flow conditions correctly, please supply a Reynolds number per meter in the config file. However, it should be noted that for the compressible solver, we do indeed use the Reynolds length in meters within the config file.
Hope this helps,
Tom
economon is offline   Reply With Quote
Old   June 13, 2014, 15:10
Thumbs up
nilesh
Thanks. I got it.
Old   July 31, 2014, 12:45
Amit
Amit_Pawarpawar is on a distinguished road
i dont know how is reynolds number per metre is exactly to be mentioned in the cfg file, please guide.
Amit_Pawarpawar is offline   Reply With Quote
Old   July 31, 2014, 20:37
hlk
Heather Kline
Set it with REYNOLDS_NUMBER - when the reynolds length is set to 1.0 they are equivalent.
