December 29, 2015, 06:48 |
parallel efficiency in SU2
Yang Muchen
Rep Power: 11 |
Hello everyone!
Recently i have been using SU2(version 4.0.1) to run a parallel computation with 32 AMD cores(2.5GHz), and the grid size is about 10 million. However, i think the calculation speed is relatively slow(RANS, no MG, about 1000 steps per day). I am wondering if anyone has run a large-scale parallel computation with SU2? How about its efficiency? Is there anything i could do to improve the performance? Any help would be appreciated. Thanks! |
January 6, 2016, 05:23 |
Tim Albring
Rep Power: 10 |
Hi ymc11,
You can check the compiler flags for optimizations (-O2, which is enabled by default). But I think you have to increase the number of cores. 32 is not enough for this grid size as AMD cores are rather slow (at least compared to Intel). |
January 6, 2016, 20:41 |
Yang Muchen
Rep Power: 11 |
Hi talbring,
Thanks for your reply. I checked the compiler flags and found that what i used was "-g".Then i built SU2 with compiler flags"-O3", and the computation is more than twice faster than before. However, as you said, i think the performance will be even better on intel cores. Thank you very much. It does help me a lot. |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
SU2 in parallel | suman91 | SU2 | 4 | September 26, 2014 20:38 |
SU2 parallel installation error | JAlbert | SU2 Installation | 2 | November 19, 2013 02:43 |
OpenFOAM with Inifiband & parallel efficiency | LijieNPIC | OpenFOAM | 15 | June 23, 2011 05:10 |
