Home > Forums > Software User Forums > SU2
Errors
Old   January 18, 2016, 10:25
Default Errors
weigl is on a distinguished road
I am trying to learn SU2, but whenever I run the NACA0012 tutorial it gives me these errors:
REF_PRESSURE: invalid option name.
REF_TEMPERATURE: invalid option name.
REF_DENSITY: invalid option name.
CFL_RAMP: invalid option name.
LINEAR_SOLVER_RELAX: invalid option name.
MGCYCLE: invalid option name.
MAX_CHILDREN: invalid option name.
MAX_DIMENSION: invalid option name.
VISUALIZE_PART: invalid option name.
DIVIDE_ELEMENTS: invalid option name.
weigl is offline   Reply With Quote
Old   January 19, 2016, 00:31
hlk
Heather Kline
hlk is on a distinguished road
Thank you for your question.
Please make sure that you are using a config file from the same version. From the errors shown, you are using a older config file with a newer code version. The newer config files can be found on the github repository.
You can also remove the indicated lines from the config file, and the code with use default values for options that are not included.
To check current config file options, see the config_template.cfg files.
hlk is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
