Home > Forums > Software User Forums > SU2
Multigrid
Old   April 18, 2016, 21:37
Default Multigrid
Tom
mlooti is on a distinguished road
hi everybody
first of all i want to thank for this fabulous code, its well written and easy to work with
1.
is it possible to track the agglomeration procedure ? I mean I want to see the hierarchy of coarse meshes?
2.
does agglomeration uses cell-based or vertex-based strategy?
3.
does code use an specific library (like MGridGen) for agglomeration process or u hand coded an algorithm?
mlooti is offline   Reply With Quote
Old   April 22, 2016, 02:00
Francisco Palacios
fpalacios is on a distinguished road
Thanks,
There is a large community of developers behind SU2, and it is always great to know that we are doing something useful for the CFD community.
About your questions:
- He have worked a lot on the MG agglomeration algorithm, and still not really happy with the results in parallel model. Any help would be very appreciated.
The main subroutine for the agglomeration is
CMultiGridGeometry::CMultiGridGeometry(CGeometry ***geometry, CConfig **config_container, unsigned short iMesh, unsigned short iZone) : CGeometry() that you can find in geometry_structure.cpp
With GetParent or GetChildren, it is possible to relate the control volume at different levels.
The agglomeration use cell-based and it is only possible first order spacial approximation.
We have never explored a specific library... it seems a good idea, If you work on that, please keep us posted. As you know, the core of the open source are the contributions from the users community.
Anyway, we worked in the past in this area, some results are in
http://www.sciencedirect.com/science...45793016300214
Best Regards,
Francisco
fpalacios is offline   Reply With Quote
Multigrid Stability Issues ThomasHermann SU2 1 November 5, 2014 16:18
algebraic multigrid vs geometric multigrid Anna Tian Main CFD Forum 5 June 18, 2013 05:03
LES by Multigrid mnabi Main CFD Forum 8 July 11, 2009 20:21
multigrid sureshkumar Main CFD Forum 0 June 9, 2006 01:20
Multigrid applied to k-e models Paulo Zandonade Main CFD Forum 9 May 24, 1999 08:10
