Home > Forums > Software User Forums > SU2
New Case F16 optimization
Old   May 26, 2016, 10:15
Default New Case F16 optimization
Tom
mlooti is on a distinguished road
Hi every body
Im trying to get familiar with adjoint optimization in SU2
so after doing almost all of the tutorials and test cases I start to do an optimization on F16 fighter jet. I make the mesh in ANSYS meshing and then convert it to su2 format.
then I solved the configuration with euler equation. the solution converged and results seems good compared to fluent. just one thin
my problem is that the lift coefficient is negative???
I know that the orientation of the plain is ok but I dont know why the lift coeff is always negative (since I can not solve the adjoint equation based on my flow results with negative lift coeff.)
bellow is some part of the config file which I think is responsible for the prroblem
% ----------- COMPRESSIBLE AND INCOMPRESSIBLE FREE-STREAM DEFINITION ----------%
% Mach number (non-dimensional, based on the free-stream values)
MACH_NUMBER= 0.9
% Angle of attack (degrees)
AoA= 0.0
% ---------------------- REFERENCE VALUE DEFINITION ---------------------------%
% Reference origin for moment computation
REF_ORIGIN_MOMENT_X = 0.00
REF_ORIGIN_MOMENT_Y = 0.00
REF_ORIGIN_MOMENT_Z = 0.00
% Reference length for pitching, rolling, and yawing non-dimensional moment
REF_LENGTH_MOMENT= 1.0
% Reference area for force coefficients (0 implies automatic calculation)
REF_AREA= 6.807157e-7
% Reference element length for computing the slope limiter epsilon
REF_ELEM_LENGTH= 0.02
% Flow non-dimensionalization (DIMENSIONAL, FREESTREAM_PRESS_EQ_ONE,
% FREESTREAM_VEL_EQ_MACH, FREESTREAM_VEL_EQ_ONE)
REF_DIMENSIONALIZATION= FREESTREAM_VEL_EQ_ONE
thanks for helping
mlooti is offline   Reply With Quote
Problem running movingCylinders case in parallel with foam-extend-3.1 mhkenergy OpenFOAM Running, Solving & CFD 5 March 3, 2017 05:20
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
COMSOL: optimization applied to a laminar flow tdh89 COMSOL 0 April 30, 2012 08:57
Transient case running with a super computer microfin FLUENT 0 March 31, 2009 11:20
