August 9, 2016, 02:20 |
Serration Depth Optimization
Sachchit Vekaria
Rep Power: 12 |
I am trying to get gradient data for L/D as objective function and serration depth as design variable. Figure is attached to explain the serration. Is there any way I can do that with existing capabilities of SU2? If yes how it is done? and if not, what is the part of the code I should be changing in order to fulfill my requirements? Thanks in advance. Sachchit |
August 16, 2016, 16:46 |
#2 | |
Heather Kline
Rep Power: 13 |
If you prefer to implement a customized design variable, you will need to modify the code including Common/src/grid_movement_structure.cpp and SU2_DOT/src/SU2_DOT, among other files. |
Motion parameter optimization | bennn | SU2 | 0 | March 9, 2016 09:03 |
increasing fluid depth | katty26 | FLOW-3D | 2 | February 21, 2015 09:10 |
Total force optimization or pressure force optimization? | robyTKD | SU2 Shape Design | 1 | August 19, 2013 15:54 |
COMSOL: optimization applied to a laminar flow | tdh89 | COMSOL | 0 | April 30, 2012 08:57 |
BOOK ON OPTIMIZATION OF FORTRAN CODES | Alberto | Main CFD Forum | 3 | November 10, 2008 06:07 |
