Home > Forums > Visualization & Post-Processing Software > Tecplot
mat2tecplot
Like Tree21Likes
Old   June 27, 2012, 19:57
Default mat2tecplot
wen long
wenlong is on a distinguished road
Dear all,
I finally finished and tested a matlab program that will dump data to tecplot binary format directly without using tecio. I'm loving it and here you go. Please see the attached mat2tecplot.m .
Simply unzip it and type in matlab command:
mat2tecplot
It will show you how it works.
Wen Long
wenlong is offline   Reply With Quote
Old   November 13, 2012, 17:59
Default updated version is attached here
wen long
Just a few updates in readme part. Zone shareing and face connections are still not yet coded. Welcome to the party.
ehsan210 likes this.
Old   November 13, 2012, 18:38
Default update again
wen long
fix a few typos in readme
Old   January 25, 2013, 15:38
Hoggs17 is on a distinguished road
Thanks for posting this code. I am hoping to use it to help validate my Matlab code for my 2-D SIMPLE Laminar flow. My Matlab visualization wasn't doing the trick so I'm hoping tecplot will do the trick. Thanks again for the code!
jadidi.cfd likes this.
Hoggs17 is offline   Reply With Quote
Old   January 31, 2013, 14:50
amine
lbmagis is on a distinguished road
Hello CFD Friends hope ur doing well
i didnt understand how it does work!!!could u help me out please???
Thank you so much
lbmagis is offline   Reply With Quote
Old   January 31, 2013, 15:04
wen long
a) Just download it, unzip it to a folder
b) open matlab
c) cd folder_where_the_mat2tecplot.m_file_is
d) help mat2tecplot
mehrzad likes this.
Old   February 1, 2013, 20:00
wen long
Just correct a few typos in readme.
ehsan210 and jadidi.cfd like this.
Old   February 4, 2013, 13:54
After reading through the mat2tecplot.m documentation, this is what I did in order to export my matlab data into a readable Tecplot file. Hope this will help any other users out there that aren't quite using it right. This is just my interpretation of Wen Long's code; all credit must be given to him for writing it.
1. You must keep the mat2tecplot.m in the same directory as your other files as your main program will call mat2tecplot.m (should be self-explanatory but you know never know).
2. In your program, you must call mat2tecplot.m and specify what data you are transferring.
3. Following the examples given in the documentation (I followed example 3 I believe), you can change a few lines of code to reflect which data you want to export. My code is as follows.
function name(inputs)
tdata=[];
tdata.Nvar=6;
tdata.varnames={'x','y','z','u','v','p_new'};
tdata.surfaces(1).zonename='mysurface zone';
tdata.surfaces(1).x=x;
tdata.surfaces(1).y=y;
tdata.surfaces(1).v(1,:,: )=u;
tdata.surfaces(1).v(2,:,: )=v;
tdata.surfaces(1).v(3,:,: )=p_new;
mat2tecplot(tdata,'SIMPLE Results.plt')
end
You have to make sure that the value specified in tdata.Nvar is equal to the number of variables you place in tdata.varnames. I specified 6 variables and then had 6 names given. I have 2-D flow (x,y,z=0) and want my data for u and v momentum and pressure exported. "tdata.surfaces(1).x= " is used to specify your domain. In the example, coordinates are given for x,y,z; in my code; i simply set the .x value equal to my x-values on my defined mesh. The same was done for the y-values. if you specify nothing (as with z), it is assumed 0.
The "tdata.surfaces(1).v(1,:,: )= " code specifies which data you want displayed as a result. i set it equal to my u momentum. To add multiple data to the same file, you change the .v(1,:,: ) to .v(2,:,: ) etc... for as many different data sets as you like. I had 3 data sets (u,v,pressure) so I have 3 lines.
Finally, the last line in the code calls mat2tecplot using the values you have specified and outputs an easily readable tecplot input file (called 'SIMPLE Results'). My contour plots for momentum and pressure look much better than they did on matlab plus you now have the flexibility of using tecplot to manipulate your visualization axis, contour # etc...
You just have to add a few lines of code to your matlab program and the mat2tecplot.m does all the work for you.
Now if I could just figure out how to transfer my streamline data I'd be all set - anyone have any tips?
Old   February 5, 2013, 01:17
wen long
Thank you for the nice explanation and I'm glad it works for you.
Two cents:
1)You can have as many zones as you want, as long as all the zones have
same number of variables and same variable names.
If you want to make a movie, you can put the first time frame in surfaces(1), and 2nd time frame in surfaces(2) etc and give solutiontime to each of them, e.g. surfaces(1).solutiontime=0.0, surfaces(2).solutiontime=1.0, ...
Then you will be able to move from one zone to another in tecplot and use &(solutiontime) in label texts to label the time.
Alternatively, instead of using solutiontime, you can use strandID
2)x,y,z are variables for 3D system, if you have only 2D dataset, then one of them can be treated as a dependent variable, and the other two as independent variable, for example z=z(x,y). (which one is dependent variable is based on order of the surface,line, FEsurface etc). In this case, x, y are called the coordinate variables, and z is a function defined on x, y coordinates, and z can be named whatever you want in varnames. Similarly, x, y do not always mean Cartesian coordinates, x, y can be polar coordinate, for example
tdata.surfaces.x=rho;
tdata.surfaces.y=theta;
tdata.surfaces.z=T;
tdata.varnames={'rho','theta','T'}
In this case, (x,y) is (rho, theta), i.e. polar coordinate ,and z is temperature defined on (rho,theta), e.g. T on a disk.
If your coordinates are on (y,z) plane, then x is treated as a dependent variable, such as tdata.surfaces.x=T, tdata.surfaces.y=y, tdata.surfaces.z=z, which means T=T(y,z), in this case you have to give the order (i.e. orientation) of the surface, that is tdata.surfaces.order=1 . In this case, x can be one of your results you want to plot, and the rest of them should be in v(ivar,:,: ). You could also give no x values at all, and put all dependent variables in v(ivar,:,: ), except that in this case x will be treated as zeros and you have to account x in the number of variables.
By default, surface order is assumed to be 3, i.e. z=z(x,y).
Similarly, for lines, if you have only 1D data, i.e. X-Y plots, i.e. y=y(x), then y,z,v etc are all going to be x's function. This is handled similarly by lines.order parameter. By default, it is assumed to be 3D lines, i.e. v=v(x,y,z) with x,y,z all being one-D array storing (x,y,z) coordinates of a series of points on the line. If you have x,z,v as function of y, then the order must be 2, i.e. you are using y as the coordinate only.
3) If you have only one zone for a type, e.g. only one surface zone, you can
use surfaces.x instead of surfaces(1).x etc, like in 2)
4)for streamlines, once you have x,y, u, v in the zone, tecplot can generate streamlines for you. If you insist using your own streamline data, e.g. streamline as a 2D curve defined by connecting multiple points, you can use the line zones in addition to the surface zones. e.g. lines(1).x=[x coordinates of the points on a stream line], lines(1).y=......, and use lines(1).z or lines(1).v(ivar,: ) for colors of the streamline or variables on the streamline points, e.g. density on the streamline. And then repeat for lines(2).x, lines(2).y, lines(2).z, lines(2).v(ivar,: ) etc for the second streamline.
5)dimension size of v(ivar,:,:,: ) is dependent on whether the variable ivar is
defined on all coordinate points or the center of an element. If at the center of element, e.g. for x,y coordinates to be 3x4, then you will only have 2x3 points to give v values for variable ivar, i.e. (3-1)x(4-1), in this case you have to specify varloc=1 for ivar'th variable in v. By default, it is assumed to be zero, i.e. on coordinate points.
6) mat2tecplot.m does NOT have to be in the same directory of your main program or data if you have added the folder name to PATH
e.g. by executing
addpath('C:\directory\name\of\mat2tecplot.m\','-end');
Normally, people put these kind of PATH setups for matlab in startup.m, please search for matlab startup.m configuration. As long as the program is in PATH, matlab knows where to find it.
Old   February 28, 2013, 17:13
sarah440 is on a distinguished road
Thanks so much, it works very well for my cases with tdata.cubes.
sarah440 is offline   Reply With Quote
Old   March 1, 2013, 08:46
amine
1/plz tell me the different steps how to do it(export contours from matlab to tecplot) shortly plz
2/i am working on CFD problem ,i wanna export matlab data and fluent 6.3 data(contours of stream functions) to same frame and plot them together in order to compare the isolines
Best wishes
Thank u in advance
Old   March 1, 2013, 11:09
Best wishes
Thank u in advance
I have a DNS database which includes the coordinate matrices x, y, z as well as the velocity fields u, v and w. All matrices have the same size of nl*nc*ns. Then I use Matlab to compute some new parameters like swirling rate. At the end of my own script I use mat2tecplot.m to convert mat files to PLT format. Here is what I put at the end of my script:
PLTout = strcat(outputAddress,PLTout_name); %The output name and address
tdata=[];
tdata.Nvar=7; %number of variables
tdata.vformat = 2*ones(1,tdata.Nvar); %Double precision for each variable (optional)
tdata.varnames={'x','y','z','u','v','w','Lambda'};
tdata.cubes(1).zonename=eval('PLTout_name'); %any name
tdata.cubes(1).x=x(nl*nc*ns);
tdata.cubes(1).y=y(nl*nc*ns);
tdata.cubes(1).z=z(nl*nc*ns);
tdata.cubes(1).v(1,:,:,: )=u(nl*nc*ns);
tdata.cubes(1).v(2,:,:,: )=v(nl*nc*ns);
tdata.cubes(1).v(3,:,:,: )=w(nl*nc*ns);
tdata.cubes(1).v(4,:,:,: )=lambda(nl*nc*ns);
mat2tecplot(tdata,eval('PLTout'))
I can easily visulize this PLT file in Tecplot
Hope this helps
Old   March 4, 2013, 08:37
amine
tdata=[];
Hope this helps
Hi Sarah,
Thank You So Much , i will try it
be in touch plz
have a nice day
Old   September 24, 2013, 21:36
Default Re : mat2tecplot.m
  #14
mn1729
mn1729 is on a distinguished road
Thanks a lot for this post. It was extremely useful. It is really hard to figure out the binary format from the tecplot manual.
mn1729 is offline   Reply With Quote
Old   December 10, 2013, 09:12
Default thanks
  #15
Marita torregrosa
Marita is on a distinguished road
I used your code for converting a set of images (ij ordered) into a volume (ijk) avoiding interpolation... I am quite new at CFD, and your code was very easy to implement. Thank you very much!
Marita is offline   Reply With Quote
Old   February 7, 2014, 07:05
Default Have problem to add the aux data.
  #16
trim
trimtrim is on a distinguished road
Hi wenlong:
I have problem to add the aux data to the FE surface. with out the add aux lines, the tecplot can open the file, However, when I add the aux data to the data zone, the file cannot be opened.
Thanks.
tdata=[];
tdata.Nvar=4;
tdata.varnames={'x','y','z','T'};
tdata.FEsurfaces(1).zonename='my surface zone';
tdata.FEsurfaces(1).x=[1,2,2.5]; %totally 5 nodes
tdata.FEsurfaces(1).y=[1,3,1];
tdata.FEsurfaces(1).order=3; %surface defiend on (y,z) coord
tdata.FEsurfaces(1).e2n=[1,2,3];%3 elements(row)
%each with 3 node numbers
%(each row has 3 columns)
tdata.FEsurfaces(1).v(1,=[10,20,30];
%temperature on 5 nodes
%only one row (temperatue)
%(the row has 5 columns)
tdata.FEsurfaces(1).auxname{1} = 'Time';
tdata.FEsurfaces(1).auxval{1} = 'TT';
mat2tecplot(tdata,'myFEsurface_yz.plt')
trimtrim is offline   Reply With Quote
Old   February 12, 2014, 07:12
wen long
Thanks I will take a look and get back to u
Old   March 4, 2014, 18:10
Exclamation
  #18
Italy
ciccio is on a distinguished road
Hi
I'm new in using TecPlot and I need it for a university project.
I downloaded the mat2tecplot.m code but I couldn't manage by myself.
My problem is the following:
I have a cube represented by a matrix 36X36X36, and for each cell center I know exactly the velocity of that cell(vx,vy,vz). The velocity field is represented by 3 different matrix, one for vx (36X36X36) same size for vy, vz.
I tried to use the example 11, but when I load in Tecplot and I try to interpolate an error window appears and says that the interpolation can be done only for nodal value. How could I solve this problem?
Thank you, any help is really appreciated
ciccio is offline   Reply With Quote
Old   March 21, 2014, 18:31
wen long
Hi ciccio
Cubes are simple, because you have 36x36x36 for the cubes vertex points and your u,v,w are on the center of each cube, that means you should supply u,v,w as 35x35x35 arrays instead.
Here is an example code
tdata=[];
tdata.Nvar=6;
tdata.varnames={'x','y','z','u','v','w'};
tdata.cubes(1).zonename='my IJK volume cubes zone';
x=(1:1:36);
y=(1:1:36);
z=z(1:1:36);
[x3d,y3d,z3d]=meshgrid(x,y,z);
tdata.cubes(1).x=x3d;
tdata.cubes(1).y=y3d;
tdata.cubes(1).z=z3d;
u3d=repmat(random('norm',0.1,0.2,35),[1,1,35]);
v3d=repmat(random('norm',0.1,0.2,35),[1,1,35]);
w3d=repmat(random('norm',0.1,0.2,35),[1,1,35]);
tdata.cubes(1).v(1,:,:,: )=u3d;
tdata.cubes(1).v(2,:,:,: )=v3d;
tdata.cubes(1).v(3,:,:,: )=w3d;
tdata.cubes(1).varloc=1;
mat2tecplot(tdata,'mycube_IJK_volume_cellcenter.pl t')
Then you can view the plot in tecplot, and attached pic is what I got.
Wen
Echem likes this.
Old   June 3, 2014, 15:37
Default mat2tecplot.m
  #20
nacera
chernac2000 is on a distinguished road
hello
I have a problem when I load data file in tecplot, the file is generate with matlab with mat2tecplot.m . I get this message: Binary file version newer than tecplot version. Upgrade Tecplot or use an older preplot to produce the data
chernac2000 is offline   Reply With Quote
