January 18, 2015, 17:42 |
Matlab to Tecplot
amine
Rep Power: 13 |
Hello friends,
the problem is: there is a 2D domain (square for example) which i need to simule the temperature (heat transfer) through it using a matlab code. well when we run the code (the data updated every time unit"iteration"), at the end we will obtain a contour of Temperature. I would like to know the way i could export this data (temperature contour) from matlab to tecplot in order to make a post-processing using the mat2tecplot code. i tried it many times but it didnt work. Can anyone give me the code to do that???Thank you |
January 22, 2015, 18:57 |
Check out the resources on writing data from MATLAB
Hi lbmagis,
We have some example code for writing data from MATLAB to Tecplot *.plt here. (http://www.tecplot.com/blog/2014/07/...s-matlab-data/) I am not sure that this will help with the formatting the data from an iteration perspective. Please send me your code and I can see if I can trouble shoot it. d.rittenberg@tecplot.com. Durrell |
Matlab to tecplot 9.0 | lbmagis | Main CFD Forum | 0 | July 5, 2012 18:34 |
how to import matlab file(lid-driven cavity 2d flow) in tecplot 9.0.0-9 | lbmagis | Tecplot | 0 | June 30, 2012 10:21 |
lid-cavity :No Bmp loader or Matlab loader on my Tecplot 9.0.0-9 | lbmagis | Tecplot | 0 | June 29, 2012 19:18 |
I created a tecplot binary file... | Lupocci | Tecplot | 6 | June 27, 2012 19:56 |
TECPLOT file data format Plz Explain | whats_in_a_name | FLUENT | 1 | February 21, 2007 08:50 |
